I have volunteered to help a mate transfer stuff from VHS tapes to DVD and run into an odd problem!
So far I have copied the material to a series of .mp4 files and got him to identify the start/stop positions of the sections he wants to extract and keep.
Not sure what program he used to view the files, but, he is on Windows and would be something that came as standard I think.
On my PC, I have looked at a couple of the files (using both Lossles Cut and VLC Media Player) and the timings don't seem to match! So, if I look at a section with his start/end times then it doesn't correspond with a sensible segment of video.
He swears blind that on his PC then the timings are right.
Bit of a loss as to why they are not same on my PC. Is it possible that different PCs or software could introduce different timing on the .mp4 files?
Or, any other suggestions why they might be different?![]()
Maybe the time codes indicate vfr and one player is respecting them and others do not.
PotPlayer strange playlist delay issue
By Dreamer in forum Software PlayingReplies: 7Last Post: 1st Sep 2023, 07:40 -
some help with a strange issue
By Hammer in forum Video Streaming DownloadingReplies: 6Last Post: 1st Nov 2021, 02:11 -
Strange VHS-C Issue
By vhsnewbie in forum MediaReplies: 4Last Post: 29th May 2020, 14:25 -
Strange issue with subtitle edit 3.5.7
By batemanj in forum SubtitleReplies: 1Last Post: 17th Feb 2019, 01:18 -
Strange issue with AviDemux and HEVC
By Sephiroth666 in forum EditingReplies: 4Last Post: 17th May 2018, 03:02
