Hello! I need a bit of help here. I'm not really an expert in video restoration, and I'm trying to find a way to remove annoying rainbow-like artifacts. I'm not sure what they're called.
This video is sourced from a DVD - I've attached a small sample. It's really noticeable, for example, in the scene with a close up of the girl, in her hair, or in the scene with Freddie Mercury's sillhouette, in the digital computer drawings.
I've tried various methods I thought would work, with no avail. I'd really appreciate it if someone could point me in the right direction. Cheers
Results 1 to 13 of 13
not every rainbowing artefact is the same. it would be helpful to know what have you tried before -
I didn't see much rainbowing in that clip, except near the beginning in the girl's hair. If it were me, I'd just live with it.
Nice, what did you use?
(fft3dfilter on chroma only with sigma=20, would also work but smooth chroma quite a bit)Last edited by Selur; 21st Nov 2022 at 23:33.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
The chroma blurring was done with BinomialBlur and a SMDegrain. I used a mask to apply the blurring only near chroma/luma edges.
The strong SMDegrain settings may cause some chroma ghosting.Code:Mpeg2Source(...) src = last emask = Overlay(UtoY().mt_edge(thy1=4,thy2=4), VtoY().mt_edge(thy1=4,thy2=4), mode="add").mt_expand().PointResize(width, height) emask = Overlay(emask, mt_edge(thy1=8,thy2=8).mt_expand(), mode="multiply").mt_expand().BinomialBlur(5.0) bchroma = src.BinomialBlur(0.0, 5.0, 2, 3, 3).SMDegrain(tr=5, thSAD=5000, refinemotion=true, contrasharp=false, PreFilter=4, mode=0, truemotion=true, plane=3, chroma=false) Overlay(last, bchroma, mask=emask) MergeChroma(src, last)
Note that I treated the video as progressive though it contains a few interlaced shots (most of which were b/w). It may need to be modified to work properly with interlaced shots. -
Nice.
I attached how QTGMC+maskedFFT3DFilter and QTGMC+maskedFFT3DFilter+SpotLess+MCTemoralDenoise look like.users currently on my ignore list: deadrats, Stears555, marcorocchini -
Is there any way to disable that grain freezing on QTGMC? The denoising makes the video look kinda dull, and grain freezing is really distracting. Otherwise it's a nice output must I say.
Sure, there are tons of options in qtgmc to lower the denoising.
http://avisynth.nl/index.php/QTGMC#Noise_Bypass_.2F_Denoising
http://avisynth.nl/index.php/QTGMC#Source_Match_.2F_Lossless
These can reduce the effectiveness of the antialiasing and buzz reduction. -
oh thanks these definitely will be helpful in my qtgmc usage. for a long time i'd just use veryfast to buypass denoising
Removing DVD Compression Artifacts from Textured Anime
By shark_bloody in forum RestorationReplies: 7Last Post: 22nd Mar 2021, 11:07 -
Removing dot crawl and rainbowing artifacts from NTSC dvd rip
By pm-s in forum RestorationReplies: 9Last Post: 1st Feb 2021, 05:07 -
Removing lens artifacts
By Wheaticus in forum RestorationReplies: 4Last Post: 30th Jun 2020, 11:23 -
Removing dark artifacts around halo's
By killerteengohan in forum RestorationReplies: 11Last Post: 28th Mar 2020, 11:46 -
Horizontal rainbow artifacts coming from SVHS player S-Video, not composite
By bigal100 in forum Capturing and VCRReplies: 5Last Post: 24th Mar 2020, 18:36
