Why can't I find this program in any software list? Am I missing it somehow? Or has the site deemed it not software
				Results 1 to 30 of 31
	You URL is messed up. It's here:
 https://www.topazlabs.com/topaz-video-ai
	I guess he meant the lists here -> https://www.videohelp.com/software
	Nobody here likes it since you can get free software that does a better job. I think,therefore i am a hamster.
	Tbh it deserves hate. Imagine paying for advertisements for a 200$+ program, using cherry picked examples to lure people into the rubbish that makes tons of artefacts on fine looking video... Like if you are going to make a terrible software, at least make it dirt cheap.
 Also it does not provide any other restoration methods other than deinterlacing denoising and sharpening. Like the avisyth is free and provides much more than that.
 Last of all, they like to call themselves professional grade while advertising on facebook and not having even their own wikipedia page
	Like Avisynth/Vapoursynth it's another tool that can be used and not a solution for everything. users currently on my ignore list: deadrats, Stears555, marcorocchini
	Referring to legit harsh criticism as "hate" from "haters" is dismissive, passive aggressive even.
 It still doesn't change the deserved criticism in the slightest.
 Even junk sells.
 And the world is full on stubborn contrarians.
 Or the gullible. ("But they said their stuff is good!" Well, duh.)
 If a company canned farts, and called it rose scented, somebody would buy it, defend the purchase, and insist it smells like roses. Sometimes humans are truly stupid.Want my help? Ask here! (not via PM!)
	Again. How is it I can't find it in any of the software lists. I'm not great at searching websites to find stuff sometimes. Using the wrong wording etc...wrong list. Ah well probably hidden in plain sight
	"the software lists"...? On this site? It isn't, as has already been mentioned. Most of the software on these lists have been suggested by a member, then vetted, then finally decided by Baldric or the Mods and published or not. It hasn't made the cut yet.
 There are a number of apps that are still good that I have suggested that never made it to these lists. So what? It's a bonus if it is here, but that doesn't make it gone otherwise. The app in question can easily be gotten from the manufacturer site, linked in Post#4.
 Whether it is good or not is another topic, and one that has already been fully discussed.
	Thank you Cornucopia. Wanted to see the reviews and ratings from users on this site. Alas not to be found.
	There is a discussion about this software:
 https://forum.videohelp.com/threads/399360-so-where-s-all-the-Topaz-Video-Enhance-AI-discussion
 It has about 19 pages, some love it, some talk against it, that there is free apps that can be used instead.
 Free apps (and their filters) are not easy to use, some knowledge is needed. Talking about Avisynth or Vapoursynth and theirs library filters. So video needs to be evaluated and then filers downloaded and used in their scripts.
 Topaz is perhaps designed so anyone can use it right away, GUI oriented.
 Either you dedicate some time and try to make those scripts to work with those free tools with help of this forum or just use Topaz or something else.
 These sort of automated tools will be popping out more and more. Quality might differ, and also it depends what your source is. Regular human would say anything sharper and with more contrast (or tiny it more saturated) looks better.
 Some ai tools go and certainly will go too far, and this is a direction it is going, it will just construct new reality really (hair, skin, structure of the objects) based on trained models. Love it or hate it.
 Scripting tools are more versatile in a sense you can fix, restore videos, but it certainly takes a lot of time to come up with a script, identify the problem and find a filter or better correct sequence of filters.
	Yes I've gone through that discussion here and at doom plus watched YouTube clips. I've downloaded the program and crashed my computer awhile back. Need a better GPU. I think. I'm not skilled enough or just tool lazy to figure out avisynth n scripting. Prefer programs like tmpgenc with easier interfaces. I believe the program is neither rubbish nor miracle but where it lies between those 2 extremes is the question.
	What I don't understand is the expectation that a "simple", EZ tool would regularly and consistently satisfy the needs of a complex problem.
	That's the key point, Scott. It requires days or weeks of effort to find the best AviSynth/VapourSynth script/filtering/parameters to perform the best restoration, and people think that few clicks on a GUI can perform the same. No way.
 BTW, the good results obtained by JoelHruska in the mentioned thread merging AviSynth and Topaz VEAI required weeks of effort. The same for the best AviSynth results showed there.
	Like or dislike the program and its price, it does something very easily (and quite well) that amateurs can't do.
	False.it does something very easily (and quite well) that amateurs can't do.
	Did you mean "simple to use" machine learning FPS conversion ? or did you mean "simple way" algorithm conversion (ie. duplicates, blends) ?
 Flowframes is an easy to use GUI than can use RIFE, DAIN, some others
 https://nmkd.itch.io/flowframes
	He probably meant AviSynth SVSmoothFps or FrameRateConverter or similarDid you mean "simple to use" machine learning FPS conversion ? or did you mean "simple way" algorithm conversion (ie. duplicates, blends) ?
	RIFE 4.x models can use non integer multiples (but older models like 2.3, 2.4 are better in terms of quality). Not sure if 4.x is available in the free version of flowframes
 I'm not up to date on the GUI's , but there are other GUI's . Some of them are pretty cluttered. Maybe that's enough reason to pay for other software e.g
 https://github.com/AaronFeng753/Waifu2x-Extension-GUI
 Some features might not be free, not sure I don't really use the GUIs
 I use the vapoursynth/avisynth versions, or the python versions of the various projects if they don't have a vapoursynth port. I think some some GUI's like hybrid have RIFE too, but you need a special download from selur
 I also use VEIA. because it can be useful tool for some scenarios. But it's not very good if you use it 1-click. You need pre/post processing to get ideal results - ie. you have to use other tools anyways
	Don't be fooled.
 This is Topaz MO (modus operandi), going back at least 15 years now.
 Here are the steps:
 - BS low-knowledge users that a complex problem can be solved by their low-quality software (photo, video)
 - find lemmings to promote it, by giving out free copies
 - after sustained bad legit reviews (not the gushing BS), end the software
 - advertise that a "new" program is coming out, even bolder promises/BS
 I knew this was coming. I wrote it in a post here at least a year ago.
 I wonder what dumbass is going to pay $300 for a GUI to inferior software. Want my help? Ask here! (not via PM!) Want my help? Ask here! (not via PM!)
  so where's all the Topaz Video Enhance AI discussion?By brandon87 in forum Video ConversionReplies: 575Last Post: 19th Jul 2023, 06:37
  Alternative to Topaz Video Enhance AI ?By tempes1971 in forum Video ConversionReplies: 4Last Post: 5th Sep 2021, 14:25
  Topaz productsBy taigi in forum RestorationReplies: 25Last Post: 1st Jun 2021, 10:56
  Topaz's video enhance ai is rubbishBy pm-s in forum Video ConversionReplies: 9Last Post: 30th May 2021, 08:48
  Do I need to convert colorspace before upscaling in Topaz Video EnhanceBy LaserBones in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2020, 06:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
