So far I've been using an MHL adapter which doesn't support subtitles and I had to hardcode them. It works well otherwise.
I was thinking of getting Chromecast, but as far as I know it has the same problem. The solutions I found on the net seem to be very inconsistent.
I just don't want to embed subs (which involves reencoding, obviously) every single time I want to watch something.
Is there really no way of playing a simple MP4/MKV + SRT on my phone and displaying it on a TV screen? That's all I want.
Results 1 to 9 of 9
What is mhl adapter?
Does your tv have a DLNA receiver/player ?
You may be able to cast using an app such as Web Video Caster
or BubbleUpnp.
If you have a separate SRT on the phone, casting to Chromecast would work
with WVCLast edited by davexnet; 24th Nov 2022 at 15:33.
It's a dirt cheap Micro USB -> HDMI adapter which can be used with some old phones (Galaxy S5, for instance). Works like a charm.
https://www.mhltech.org/devices.aspx?tid=1 -
Simple! just remux (no re encoding involved) with MKVToolnix adding in your subtitle/s and making it the default sub if you wish. This way means you can turn on or off subs via the remote on your media player. This method doesn't embed the subs into the video and no change of quality. Quite quick to do around 2 or 3 minutes depending on the length of the film.
PS I have Chromecast on my A/V receiver and built in to my TV and if I invoke a file on my iPad with subs it plays ok as does Netflix with subs, at 84 I'm hard of hearing due to age related hearing loss <groan> !!!!!Last edited by netmask56; 30th Nov 2022 at 00:25.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
I read somewhere that it might make a difference if the subs are in .ASS/.SSA or .SUB + .IDX format instead of .SRT. So, not just "normal" text files. Can anyone confirm?
Also, supposedly it helps if you just "mirror" the phone's screen as opposed to... doing it another way. I really don't know. As long as everything stays in sync and the video isn't losing frames, it's fine. -
Well I don't have Android but I do have iPhone and iPad and Zidoo (Android 9 media player) and all my video's have subtitles within the MKV file structure and play just fine. On the Zidoo 3000 it doesn't care if the srt subs are in the MKV container or as a separate file (same name as video .srt) The operating system of the Zido players is Android (9).
Be adventurous and try it on someone else's Android phone or whatever!SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Using an Android Phone the only way I have found to cast subtitles that are embedded is to play the video on the phone (using VLC) and choose to cast the screen from the Operating System's cast option.
All other apps I've tried fail to cast subtitles.Noob Starter Pack. Just download any Widevine media! Over 22,000 downloads for V6!.
Downloading and decryption on your Android phone.
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 28Last Post: 21st Oct 2023, 20:02 -
how do i send files from an android phone to an ubuntu laptop using wifi?
By oduodui in forum LinuxReplies: 10Last Post: 3rd Jul 2022, 14:21 -
Fle recovery from android phone that wont boot.
By dafoe in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2021, 21:22 -
Delete
By Ertoil in forum Authoring (DVD)Replies: 0Last Post: 3rd Aug 2021, 06:47 -
MKV/H264 to MP3 (or audio format compatible with Android phone)
By alexeliasson in forum AudioReplies: 2Last Post: 10th Feb 2021, 07:35
