too much work for me LOL, I'm happy with these
Try StreamFab Downloader and download streaming video from Youtube, Netflix, Amazon! Download free trial.
Results 31 to 39 of 39
Now, if you had followed my advice earlier of paying attention to how the site works, you'd have realised that all that is need is the token. Sniff the token from your LGTV and use that to obtain your decryption key. Making sure to note that you are indeed detecting a widevine stream and not a MSPR stream. If it's MSPR your scripts won't help you.
Or do you want me to shut up and fellate a relative? as you abusively requested yesterday. -
I can assure you, a token is being sent with the mpd request. You just have to sniff it. That token is needed as part of the decryption key request to the key server.
All4, uses the same server and same CDN method, across all platforms it's official applications are installed on.
In some cases the app is merely a wrapper to access the website, in others it's a separate channel.
the MPD and token changes depending on the user string and device ID.
Sniffing out the mpd from the tv will also supply you with the token, pay attention to what you are sniffing and work slowly through the capture.
I'm getting the feeling you really haven't a clue about all this and merely want other peoples work and claim it as your own.
As well as your serious interpersonal issues. -
What are you using the sniff the url? httptoolkit needs a rooted device to install unsigned certs to sniff full web traffic.
Wireshark will find the bare minimum.
Cain and Abel?
Burpsuite?
SSLStrip?
Netop Vision? -
And I can't root your tv for you, either.
C4 have additional protections on their streams, they obfuscate the token. Root a firestick, use httptoolkit, inject the unsigned certs and your see the traffic fully.
But all that is need is the token supplied by the stream.
A Downloader that works with the UK's Channel4 aka All4
By pooksahib in forum Video Streaming DownloadingReplies: 9Last Post: 21st Feb 2023, 06:25 -
Need Help in Getting Keys
By Game_Trips in forum Video Streaming DownloadingReplies: 6Last Post: 10th Oct 2022, 11:00 -
WKS-KEYS help
By Gruchemuche in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Oct 2022, 08:55 -
How to get the keys
By 10362227 in forum Video Streaming DownloadingReplies: 2Last Post: 18th Jun 2022, 20:25 -
Can anyone help with getting keys?
By fisfisa in forum Video Streaming DownloadingReplies: 8Last Post: 1st Mar 2022, 00:33
