how can i get keys for all4 tv shows? please help me thanks
Results 1 to 30 of 39
got the tool but cant get it to work can u help plz write a step by step guide or make a video showing how please
yes i have cdm, i cant install pywidevine for some reason can u help please, what version of python are u using? can u make a .rar file with all your python and ch4 files so i can use it please mines not working but my cdm is new and i havnt used it on any other script yet, but i dumped it myself
all i get when i try to install pywidevine via cmd is
ERROR: Ignored the following versions that require a different python version: 1.0.0 Requires-Python >=3.7,<3.11; 1.0.1 Requires-Python >=3.7,<3.11; 1.1.0 Requires-Python >=3.7,<3.11; 1.1.1 Requires-Python >=3.7,<3.11; 1.2.0 Requires-Python >=3.7,<3.11; 1.2.1 Requires-Python >=3.7,<3.11; 1.3.0 Requires-Python >=3.7,<3.11; 1.3.1 Requires-Python >=3.7,<3.11; 1.4.0 Requires-Python >=3.7,<3.11; 1.4.1 Requires-Python >=3.7,<3.11; 1.4.2 Requires-Python >=3.7,<3.11; 1.4.3 Requires-Python >=3.7,<3.11; 1.4.4 Requires-Python >=3.7,<3.11; 1.5.0 Requires-Python >=3.7,<3.11; 1.5.1 Requires-Python >=3.7,<3.11; 1.5.2 Requires-Python >=3.7,<3.11
ERROR: Could not find a version that satisfies the requirement pywidevine>=1.4.3 (from versions: none)
ERROR: No matching distribution found for pywidevine>=1.4.3
and when i try to run the script i get:
pip install Crypto
pip install Crypto
Requirement already satisfied: Crypto in c:\users\danny\appdata\local\programs\python\pytho n311\lib\site-packages (1.4.1)
Requirement already satisfied: Naked in c:\users\danny\appdata\local\programs\python\pytho n311\lib\site-packages (from Crypto) (0.1.32)
Requirement already satisfied: shellescape in c:\users\danny\appdata\local\programs\python\pytho n311\lib\site-packages (from Crypto) (3.8.1)
Requirement already satisfied: requests in c:\users\danny\appdata\local\programs\python\pytho n311\lib\site-packages (from Naked->Crypto) (2.28.1)
Requirement already satisfied: pyyaml in c:\users\danny\appdata\local\programs\python\pytho n311\lib\site-packages (from Naked->Crypto) (6.0)
Requirement already satisfied: charset-normalizer<3,>=2 in c:\users\danny\appdata\local\programs\python\pytho n311\lib\site-packages (from requests->Naked->Crypto) (2.1.1)
Requirement already satisfied: idna<4,>=2.5 in c:\users\danny\appdata\local\programs\python\pytho n311\lib\site-packages (from requests->Naked->Crypto) (3.4)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in c:\users\danny\appdata\local\programs\python\pytho n311\lib\site-packages (from requests->Naked->Crypto) (1.26.12)
Requirement already satisfied: certifi>=2017.4.17 in c:\users\danny\appdata\local\programs\python\pytho n311\lib\site-packages (from requests->Naked->Crypto) (2022.9.24)
what python version do u use?
im getting this now:
C:\Users\danny\Desktop\c4-dl-master\c4-dl-master>py .\c4-dl.py --download --wvd "C:\widevine_device.wvd" --url "https://www.channel4.com/programmes/the-big-bang-theory/on-demand/44564-001"
File "C:\Users\danny\Desktop\c4-dl-master\c4-dl-master\c4-dl.py", line 10, in <module>
import requests
ModuleNotFoundError: No module named 'requests'
i tried to install requests via pip install requestsLast edited by Dannyboi; 22nd Nov 2022 at 14:47.
all the ch4 files I have are the script from github
all the python files I have is the installation file for python v3.10.3
"Requires-Python >=3.7,<3.11"
this means it requires python version higher than or equal to 3.7 AND lower than 3.11
I see you're using 3.11, so I guess that's the problem -
and did requests install or was there an error or was there no output at all? i'm not a python guy, I work with javascript and node.
i have uninstalled the new version and am installing that version 3.10.3, yes i installed requests
im getting the following error:
File "C:\Users\danny\Desktop\c4-dl-master\c4-dl-master\c4-dl.py", line 12, in <module>
from Crypto.Cipher import AES
ModuleNotFoundError: No module named 'Crypto'
C:\Users\danny\Desktop\c4-dl-master\c4-dl-master>pause
Press any key to continue . . .
i have tried pip install crypto, but all im getting is this still
ModuleNotFoundError: No module named 'Crypto'Last edited by Dannyboi; 22nd Nov 2022 at 15:03.
try this:
https://stackoverflow.com/questions/19623267/importerror-no-module-named-crypto-cipher...48720#39048720
in the future try googling the error itself, i got this by googling ModuleNotFoundError: No module named 'Crypto'
stackoverflow is good for these kinds of problems -
i have its not working:
warning: GMP or MPIR library not found; Not building Crypto.PublicKey._fastmath.
building 'Crypto.Random.OSRNG.winrandom' extension
error: Microsoft Visual C++ 14.0 or greater is required. Get it with "Microsoft C++ Build Tools": https://visualstudio.microsoft.com/visual-cpp-build-tools/
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: legacy-install-failure
× Encountered error while trying to install package.
╰─> pycrypto
note: This is an issue with the package mentioned above, not pip.
hint: See above for output from the failure. -
also im getting this error when i tried to do this: pywidevine create-device -k device_private_key -c device_client_id_blob -t "ANDROID" -l 3 -o output
C:\Users\danny\Desktop\c4-dl-master\c4-dl-master>pywidevine create-device -k device_private_key -c device_client_id_blob -t "ANDROID" -l 3 -o c4-dl-master
INFO:root
ywidevine version 1.5.2 Copyright (c) 2022 rlaphoenix
INFO:root:https://github.com/rlaphoenix/pywidevine
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\lib\runpy.py", line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\lib\runpy.py", line 86, in _run_code
exec(code, run_globals)
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\Scripts\pywidevine.exe\__main__.py", line 7, in <module>
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\lib\site-packages\click\core.py", line 1130, in __call__
return self.main(*args, **kwargs)
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\lib\site-packages\click\core.py", line 1055, in main
rv = self.invoke(ctx)
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\lib\site-packages\click\core.py", line 1657, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\lib\site-packages\click\core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\lib\site-packages\click\core.py", line 760, in invoke
return __callback(*args, **kwargs)
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\lib\site-packages\click\decorators.py", line 26, in new_func
return f(get_current_context(), *args, **kwargs)
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\lib\site-packages\pywidevine\main.py", line 232, in create_device
out_path.write_bytes(wvd_bin)
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\lib\pathlib.py", line 1141, in write_bytes
with self.open(mode='wb') as f:
File "C:\Users\danny\AppData\Local\Programs\Python\Pyth on310\lib\pathlib.py", line 1117, in open
return self._accessor.open(self, mode, buffering, encoding, errors,
PermissionError: [Errno 13] Permission denied: 'c4-dl-master\\amlogic_mbox_v4.1.0-android_99908892_4445_l3.wvd' -
i think the pywidevine error is because the folder that it is trying to write the output to doesn't exist.
the setup needs to be like this:
folder named folderA contains: device_private_key, device_client_id_blob and an empty folder named folderB
then from folderA you call the "pywidevine create-device" command and for "-o" you use folderB -
for crypto: it is again literally telling you what you need to do
"error: Microsoft Visual C++ 14.0 or greater is required." means that you need to install Microsoft Visual C++ version 14 or greater
https://www.google.com/search?q=Microsoft+Visual+C%2B%2B&rlz=1C1BNSD_enHR997HR997&sour...hrome&ie=UTF-8 -
im getting this now: when trying: pywidevine create-device -k folderA\device_private_key -c device_client_id_blob -t "ANDROID" -l 3 -o folderB
C:\Users\danny\Desktop\c4-dl-master>pywidevine create-device -k folderA\device_private_key -c device_client_id_blob -t "ANDROID" -l 3 -o folderB
INFO:root
Usage: pywidevine create-device [OPTIONS]
Try 'pywidevine create-device --help' for help.
Error: client_id: Not a path to a file, or it doesn't exist.
and
C:\Users\danny\Desktop\c4-dl-master>pywidevine create-device -t ANDROID -l 3
INFO:root
Error: Missing option '-k' / '--key'.
C:\Users\danny\Desktop\c4-dl-master>pywidevine create-device -t ANDROID -l 3 -k
INFO:root
Error: Option '-k' requires an argument. -
you are making a big mess out of something very simple
create folder named folderA. copy device_private_key and device_client_id_blob into it. then enter folderA. create empty folderB inside folderA. open command prompt (cmd) and navigate to folderA. enter THIS EXACT COMMAND: pywidevine create-device -k device_private_key -c device_client_id_blob -t "ANDROID" -l 3 -o folderB -
ok done that:
C:\Users\danny\Desktop\c4-dl-master\folderA>pywidevine create-device -k device_private_key -c device_client_id_blob -t "ANDROID" -l 3 -o folderB
INFO:root
INFO:create-device:Created Widevine Device (.wvd) file, amlogic_mbox_v4.1.0-android_99908892_4445_l3.wvd
INFO:create-device: + Type: ANDROID
INFO:create-device: + System ID: 4445
INFO:create-device: + Security Level: 3
INFO:create-device: + Flags: None
INFO:create-device: + Private Key: True (2048 bit)
INFO:create-device: + Client ID: True (1766 bytes)
INFO:create-device: + VMP: False
INFO:create-device: + Saved to: C:\Users\danny\Desktop\c4-dl-master\folderA\folderB\amlogic_mbox_v4.1.0-android_99908892_4445_l3.wvd
but still getting this error for some reason can u help with it please?
C:\Users\danny\Desktop\c4-dl-master>py .\c4-dl.py --download --wvd "C:\widevine_device.wvd" --url "https://www.channel4.com/programmes/the-big-bang-theory/on-demand/44564-001"
File "C:\Users\danny\Desktop\c4-dl-master\c4-dl.py", line 12, in <module>
UPDATE: Think i fixed it as its now downloading from channel 4
Update 2: Getting this now:
[!] Failed merging streams !!!
File "C:\Users\danny\Desktop\c4-dl-master\c4-dl.py", line 524, in <module>
main()
File "C:\Users\danny\Desktop\c4-dl-master\c4-dl.py", line 520, in main
merge_streams(files, output_title)
File "C:\Users\danny\Desktop\c4-dl-master\c4-dl.py", line 401, in merge_streams
os.mkdir(output_dir)
FileNotFoundError: [WinError 3] The system cannot find the path specified: './downloads/British.Army.Girls.British.Army.Girls.WEB-DL.1080p.H.264.AAC'
C:\Users\danny\Desktop\c4-dl-master>pause
Update 3: its downloaded and decrypted
install Microsoft Visual C++ version 14 or higher
then repeat the process fromt he stackoverflow answer i linked -
got it working now thanks now all i need to do is update the script to mux the decrypted mp4 files
neither ffprobe nor yt-dlp's --list-formats show this hgiher quality stream
is it possible it's available only on some shows?
i have seen a scene all4 rip with 5000k bitrate, the other scene all4 rips are usually 3000k
EDIT: you're right, I just tried downloading an episode of Screw with Diazole's script and got ~3000k, while SDCC's scene WEB-DL has 5000kLast edited by ampersand; 24th Nov 2022 at 17:39.
all tv shows see this mpd from my lgtv has higher bitrate: http://cf.p06.c4assets.com/xbox/CH4_29_02_29_73860001001001_001_HD.ism/Manifest?c3.ri=...68154391755162 need a way to get c4 script to download and decrypt it with l3 keys see below:
Selected MPD :
[generic] Manifest?c3: Requesting header
WARNING: [generic] Falling back on generic information extractor.
[generic] Manifest?c3: Downloading webpage
[generic] Manifest?c3: Extracting information
[info] Available formats for Manifest?c3:
ID EXT RESOLUTION | TBR PROTO | VCODEC VBR ACODEC ABR ASR MORE INFO
audio_eng-128 isma audio only | 128k ism | AACL 128k 48000Hz 48000Hz
video-498 ismv 512x288 | 498k ism | AVC1 498k
video-795 ismv 640x360 | 795k ism | AVC1 795k
video-993 ismv 640x360 | 993k ism | AVC1 993k
video-1194 ismv 1024x576 | 1194k ism | AVC1 1194k
video-1492 ismv 1024x576 | 1492k ism | AVC1 1492k
video-1987 ismv 1280x720 | 1987k ism | AVC1 1987k
video-2978 ismv 1920x1080 | 2978k ism | AVC1 2978k
video-4962 ismv 1920x1080 | 4962k ism | AVC1 4962k
website mpd: https://ak-jos-c4assets-com.akamaized.net/CH4_08_02_900_73860001001001_001/CH4_08_02_9...HzxtO6Q3D3VD-8
tv mpd: http://cf.p06.c4assets.com/xbox/CH4_29_02_29_73860001001001_001_HD.ism/Manifest?c3.ri=...68154391755162
i downloaded the video and audio of the highest bitrate from tv mpd but my keys cant decrypt can anyone help plz?Last edited by Dannyboi; 24th Nov 2022 at 17:51.
ok, so have I got this right - you're playing the episode from the same link on their web but in one case it's playing on a PC and in another on a TV and they detect this and send you different manifests?
or are you playing it on your tv through some kind of all4 app for smart tvs?
how are you getting the network traffic from the tv? -
A Downloader that works with the UK's Channel4 aka All4
By pooksahib in forum Video Streaming DownloadingReplies: 9Last Post: 21st Feb 2023, 07:25 -
Need Help in Getting Keys
By Game_Trips in forum Video Streaming DownloadingReplies: 6Last Post: 10th Oct 2022, 12:00 -
WKS-KEYS help
By Gruchemuche in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Oct 2022, 09:55 -
How to get the keys
By 10362227 in forum Video Streaming DownloadingReplies: 2Last Post: 18th Jun 2022, 21:25 -
Can anyone help with getting keys?
By fisfisa in forum Video Streaming DownloadingReplies: 8Last Post: 1st Mar 2022, 01:33
