    Jan 2022
    Korea (the good one)
    Hi,
    I'd like to hear your opinion regarding what's a decent device for Hi8 tape archiving. I'd like to take a shot at direct RF digitizing and software decoding, so the quality of the analog video part after the video head is not all that important. I have a Sony DCR-TRV238E PAL camera to play with (won't be using the DV function though, the primary focus is on analog Hi8), but is it worth getting a standalone Hi8 deck (like a Sony EV-C500E), since they are rare and cost an arm and a leg, even if sold as "defective"? Besides the easier accessibility to fiddle around with, are there any significant qualitative differences in terms of heads and signal quality to justify using such a player instead of a cam for playback?
    canada
    Not worth it unless your cam doesn't work,only reason they were made so they could stay plugged in your tv and you can watch any tape you want.
    Oct 2007
    There are services that can digitize your tapes. I have had many types of tapes digitized. It saves a lot time. I keep them on an external hard drive or burn them to a DVD.
    Jan 2022
    I thought so too, but thanks for confirming that I can save the money ...
    Jan 2016
    In addition to what John said, because they were go to players for playback camcorder tapes and recording TV shows they were heavily used like VHS machines, Camcorders are only used for special occasions so head wear is minimal, that's why we use them for capturing.
  6. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi8 camcorder are obsolete. Having video archive on an obsolete platform is risky. There is no new replacement unit. A cheap set top box with recording capability is a better solution.
  7. Capturing Memories dellsam34's Avatar
    Jan 2016
    The OP is not trying to record to Hi8, he is asking about playback for digitizing.
    Apr 2003
    I learned this the hard way years ago. Purchased one from Goodwill only to learn after I got it home that the heads are worn; can't play any tapes.
