  1. Good afternoon, I have a question for you. I have two cards Blackmagic Intensity pro 4K and Blackmagic Decklink mini recorder and when I enter adobe premiere pro 2020 and in the capture settings it finds dlackmagic capture but it does not give me an image from the SDI input but only from the intensity input, but when I uninstall the intensity card in the device manager and it restarts the computer and I enter adobe again, then it works great. So my question is how do I set it up to be able to choose one card or the other without having to uninstall intesity.
    canada
    Sounds like a sharing error,not sure if you can get around that,only way you can get a better answer if someone else with the same 2 cards or similar found a way or not.
    Apr 2003
    I have never had this problem but you might try swapping slots to see if the behavior continues.
