There's no 24i on either DVDs or Blu-rays. And restoring 24p from 29.97 depends of whether it's hard or soft pulldown. A DVD player will return 24p if from a soft telecined source. Most DVD players (the flag readers) will deinterlace for output the hard telecined sources. And, of course, they will deinterlace true 29.97i video.
But maybe that jerkiness you notice is just the inherent nature of film sources played on a 60 Hz television set. With a fully progressive 24p film source, every 5th frame has to be duplicated.
				Results 31 to 36 of 36
	Last edited by cornemuse; 22nd Dec 2022 at 11:56. Reason: feng shui Yes, no, maybe, I don't know, Can you repeat the question?
	I used DVDFab12's VOB Passthrough mode to rip an episode from the dvd then used VirtualDub's Direct Stream Copy/Export Stream copy & marked in/out a 50 second clip. Hopefully this didn't add any processing.
 MediaInfo stats are the same for both the original ripped .vob and VirtualDub .vob except the VirtualDub .vob has a slightly higher bit rate (4197 vs 3716 kbps).Last edited by clashradio; 23rd Dec 2022 at 20:23.
	Good sample. Like all NTSC DVDs, it's 29.97fps. It's been soft telecined and if the entire thing is like that, you can use 'Forced Film' in DGIndex and make an already progressive 24p D2V for your AviSynth script. However, that rarely happens and safer might be to use 'Honor Pulldown Flags' in DGIndex and make the script like so:
 TFM(d2v="720x480 24i.d2v")
 TDecimate()
 I still have no idea why your television says 24i. 24p, possibly, but 30i is better yet.
  pioneer DV-3052V region free: SKIPPING, 'out of region' errorBy Favorite in forum DVD & Blu-ray PlayersReplies: 0Last Post: 11th Oct 2022, 15:19
  DVD Region CodeBy biferi in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2019, 13:34
  Region A Bluray rip to play in Region B UKBy efiste2 in forum Blu-ray RippingReplies: 4Last Post: 10th Mar 2019, 18:56
  I have a Sony DVP-NS55P with no region, is it a multi-region dvd player?By albert0001 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Aug 2018, 23:13
  TV/DVD multi region helpBy H20 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2018, 16:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
