So I was recording something with OBS and the power cut out (twice...), and although OBS is supposed to finish the files if you do them as .flv or .mkv, I don't seem to be able to play these files or extract from them, though the size of the files seems about right, so I'm hoping there's a way to save the audio from them.
VLC didn't work, I can't open or convert them, I also tried FLV Extract and it told me they're not .flv files and didn't do anything.
Can anyone help me with these? I'm not sure where to go from here.
Your files are bad,nothing you can do for them.
Damn, well, I'll cross my fingers for a second opinion just in case, but thanks for having a look.
johns0 +1
The files ar empty, nothing can be done.
[Attachment 67650 - Click to enlarge]
How to extract libvo_aacenc audio from an MP4 file on windows ?
By jack616 in forum AudioReplies: 10Last Post: 19th Dec 2021, 10:25 -
How to extract audio from *.ts file without re-encoding or losing quality
By vlp_007 in forum AudioReplies: 2Last Post: 9th Dec 2021, 04:14 -
Unable to extract audio data to wave file on Subtitle edit 3.5.16
By Nakasofi in forum SubtitleReplies: 1Last Post: 14th Sep 2020, 05:42 -
How to extract audio track of .avi file to include it in a .mkv file?
By nickiman in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2019, 07:15 -
how to extract lossless audio from an MKV file - ffmpeg fails
By batemanj in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2019, 08:50
