hi, I've never encountered such a situation before,
Before to start, I just wanna be sure how to proceed correctly when the logo is cut in half by the crop.
1. I do as usual - I first crop, then I ImpaintLOC, but with no "+20 extra pixels" in the bottom side?
or
2. I first remove the logo, then I crop?
https://www.dropbox.com/s/jdvvrwia7fd6m6z/In%20ascolto%20-%20cut_track1_%5Bund%5D.mkv004100.png?dl=0
Results 1 to 16 of 16
If a border is constant then crop it before delogo and use "NoBorderAt", in your case NoBorderAt="bottom". That's for Analyze 2/-2 only, for Analyze 1/-1 there is auto-detection of "noborder" for it [but it doesn't detect if there are two "noborders"].
Code could be rewritten to auto-detect for Analyze 2/-2 too, but I'll not bother with that unless I'll encounter a logo where it has two "noborders"... then I'll would I need to rewrite Analyze 2/-2 & 1/-1 stuff.
Code:# String "NoBorderAt" : Parameter only for "Analyze" 2/-2. # Must be set accordingly if there is no border between logo and "Loc" border, or there is less than 10 pixels. # Accepts: "top", "bottom", "left", "right" or "none" (default: "none")
PS:
To implement auto stuff I needed this feature implemented: https://github.com/AviSynth/AviSynthPlus/issues/298
Recently I learned that "RT_YPlaneMinMaxDifference" can do masked MinMax, so it can be used as an alternative.
PS2:
It's InpaintDelogo & InpaintLoc.Last edited by VoodooFX; 9th Nov 2022 at 10:33.
ok thx I now try.
anyway i think the fisrt part, the intro, has a different crop, 1 line less. I apply the crop of most of the scenes need.
https://www.dropbox.com/s/bq9jz9sd6p476yr/diff%20crop.png?dl=0
Code:LoadPlugin("C:\MeGUI-2913-64\tools\lsmash\LSMASHSource.dll") LWLibavVideoSource("C:\DVB-T\TS cut\MKV\In ascolto - cut_track1_[und].mkv") AssumeFPS(25) #propDelete("_FieldBased") crop(0, 130, 0, -134) #InpaintLoc(Loc="1680,748,-94,-0") # logo borders InpaintLoc(Loc="1660,728,-74,-0") # +20px #InpaintDelogo(mask="C:\mask.bmp", Automask=1, Loc="1660,728,-74,-0", Analyze=2, NoBorderAt="bottom") #InpaintDelogo(mask="C:\mask.bmp", Loc="1660,728,-74,-0", Analyze=2, NoBorderAt="bottom", Mode="Deblend") #QTGMC(Preset="Slower", InputType=2) #bbmod(2,2,0,0,128,8) #Prefetch(7)Last edited by maudit; 9th Nov 2022 at 11:24.
i thought it was the command for fixing progressive contents...
and you said to put filters after delogo..
anyway I've added an AssumeFPS(25) that I forgot.
and these are 5min samples in ts and mkv.
https://www.dropbox.com/sh/oy3etbwp715j3j2/AAAJSKt2oiusT4r_1at2Sar4a?dl=0 -
added mask
https://www.dropbox.com/sh/oqngune8vhfgsad/AABgKqDbPu1U_Op6IBQdtJq3a?dl=0
i think is not perfect on the top left logo segment, can I fix that line? how? analyze 3? do i try it? -
I use it cause some frames have some kind of artifacts, like horizontal lines..
these are 2 frames with QTGMC on and off.
https://www.dropbox.com/sh/cotinnuyev6r414/AAA4zbomxxMPU1o-xN1yRDx5a?dl=0
don't u think is it better with QTGMC on?
anyway what about that mask? I try analyze 3 or better to left as it is?
imho it has some excessive pixels on the left top, hasn't it?
even the HD written has some "not perfect" shape..
https://www.dropbox.com/s/j07y8znnr674ifo/mask%20A2%20extra%20pixels.png?dl=0
edit: I now try analyze 3, just to see how the mask come out.
ah! no wait, I cannot, you said "NoBorderAt" is for A2 only..
so how do I create a more accurate mask?Last edited by maudit; 9th Nov 2022 at 12:35.
Do you meant that it's a little bit jagged at the left in the basemask?
No need for a super perfect basemask, such one pixel things doesn't matter.
It looks very good for me [frame 5400]:
Code:LWLibAvVideoSource("D:\In ascolto 5min sample.mkv") crop(0, 130, 0, -134) InpaintDelogo(mask="D:\mask.bmp_InpaintDelogo3_1660-728-74-0_A2-16.ebmp", Loc="1660,728,-74,-0", Show=2)
PS:
Btw, when a mask from Automask doesn't look right you can quickly adjust a basemask with aMix.Last edited by VoodooFX; 9th Nov 2022 at 13:03.
ok, the artifacts are not rare, they are everywhere, every few frames, so I will use QTGMC,
I know it slows all the process but at least it fixes those things.
about the mask, ok I got it, basemask no need to be such perfect.. I'll use that A2 then. thx!
but looking now at that your last image, not sure I understand it...
which parameters have I to use in order to get something like the image 4:final?Last edited by maudit; 9th Nov 2022 at 12:58.
ok i see, here's my show=2 frame 5930
https://www.dropbox.com/s/3zc3apvjic0eps3/In%20ascolto%20-%20cut_track1_%5Bund%5D.mkv0...show2.png?dl=0
anyway I still have no idea about that DEMO could help me..
I'm going to try some values of the following params:
I've already seen it need some grain, I try other params combos..Code:dPP=-5, GrainPP=3, Interp=3, IntSpd=4, Optimize=1
is there a way to produce a DEMO like that in order to have different images for each parameter values, automatically?Last edited by maudit; 9th Nov 2022 at 13:32.
If it looks good then you don't need to try "other params combos", especially when you don't understand what they do.
Probably for no reason with dPP=-5 you blur a lot, with Optimize=1 you add more blur + more interp artifacts and with Interp=3 you add more blur + more interp artifacts.
When default result looks good you maybe would want to reduce those parameters, not increase them.
Looking at this 5 mins sample I wouldn't change defaults [maybe except GrainPP=2]Last edited by VoodooFX; 9th Nov 2022 at 13:49.
those param values were only an examples, I've tried many..
ok fine, I've tried
GrainPP=2
vs this one
dPP=-2, GrainPP=2, Interp=0, IntSpd=1, Optimize=2
https://www.dropbox.com/s/8cri3t5z5sfrs0l/params%20comparisons.png?dl=0
and I note not much differences, so ok, I'll use GrainPP=2 only, like you suggested.
thanks. -
This is not a "demo of different parameters", it shows what's going on internally with the actual parameters used.
Open new tab in AvsPmod, change there parameters and you get different "images".
unaligned crop?
By killerteengohan in forum RestorationReplies: 3Last Post: 22nd Aug 2020, 09:12 -
the following formula not only removes logo, but also subtitle in logo area
By jraju in forum Newbie / General discussionsReplies: 33Last Post: 21st Jul 2020, 00:43 -
To crop or not to crop
By ZetaStax in forum Newbie / General discussionsReplies: 8Last Post: 2nd Oct 2019, 17:20 -
crop feature in ffmpeg
By batemanj in forum Video ConversionReplies: 5Last Post: 20th Feb 2019, 14:15 -
Unwanted crop and rotate
By untymage in forum Video ConversionReplies: 3Last Post: 9th Nov 2018, 12:40
