I want to move a clip up or down into another channel at right the exact position. It is a position off the grid between 2 frames, and with the grid enabled, it does not snap it. Same thing with snapping disabled.
When I try to move it, with snapping enabled it shows an orange line, as if it would be placed there:
but it snaps into the line of the position of the video you are at:
Anyone knows how does this work? i've been using this software for years, and I don't know how to do this, so I literally put my finger in the screen where the orange line is and then move the clip there.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Sort of change your habits, use markers(bookmarks):
If zoomed out, it will snap to your current cursor position if it is really close, vegas things that's the place to drop it. So double click a clip, Cursor will jump right to your clip/event edge and then you can precisely move it up. If you need to keep a track of that previous position, just store it pressing "M", it will create a marker, then just clicking on that marker's flag later your cursor would jump back there. Or there might be other ways. -
There are fixed snap points for a video track depending on the event and project frame rate. Audio track can be positioned pretty much anywhere. Have you changed frame rate on your project? This can cause misalignment, and the snap point will shift.
Not sure what you do, I can move it couple of frames as I described. Did you try using those markers?
Make sure you have quantize to frames turned off (alt+F8 to toggle on/off)
Vegas set clip to specific time question
By MajorFoley in forum Newbie / General discussionsReplies: 0Last Post: 20th Dec 2021, 07:34 -
FFMPEG changing audio channel position
By iKron in forum AudioReplies: 8Last Post: 3rd Jun 2021, 23:44 -
Subtitle position depending on the position of an other text
By Valit in forum SubtitleReplies: 1Last Post: 25th Dec 2020, 07:46 -
Very Basic Editing on VSDC : Move One Clip in a Layer but not the Other.
By Frisbieinstein in forum EditingReplies: 0Last Post: 6th Jul 2020, 00:20 -
How to move this clip,which was so middle of the timeline, to left side?
By Ganesh Ujwal in forum Newbie / General discussionsReplies: 1Last Post: 4th Jun 2020, 11:01
