Hi,
Can somebody help me with the following:
1. I am trying to automatically change the resolution of many vids. When I add them to xmedia recode I can change it one by one, when 'keep aspect ratio' is active so it does change the 2nd line respectfully/corrects based on 1st line I have changed.
But I cannot find a way to put all the files as one batch to reduce their resolution for example to 720p on the long side so the short one is automatically corrected (even with different aspect ratios like 4;3 and 21;9).
2. Since I have this issue with the XMR I am looking for another software that can do the thing I mentioned above properly with option to tune x264 with a GUI. Can somebody recommend an alternative?
3. Similar to 2nd question, but what is the best or most stable and well known software that contains all the x264 keys as a GUI? I don't remember all of them but I would like to use them and to have option to select them via GUI so I can properly recode my large video base to save up on space...
At this point, maybe I should go with the AV1 instead, but it is nowhere near it should be especially if we consider ultimately slow encoding times (I heard it even slower than x265 placebo by few times)?
4. Do we have an up to date modern guide to all x264/265 and maybe av1 keys explained? I had few old guides saved somewhere but they were not properly explained or semi-vague...I need something good, really GOOD and well explained.
I want to create a superb preset to preserve my BluRay remuxes in similar to lossless quality at a smallest size possible
PS Sorry if there is a better place to ask-I was looking for one, but failed to find a place for noob questions.
Thanks for the suggestion, but it cannot change resolution accordingly...I do not understand why it is so hard for many devs of similar software to implement an option when you set the long side and the short one will be reduced accordingly as well...otherwise looking good. I should spend more time with it
It changes resolution for me,you just have to change some of the settings to do that.
Go into vidcoder encoder settings/sizing and see the cropping and sizing options,there you can set it so all files will encode at 720 even if some are 4:3 or 6:9,they will stay at the proper ratio,you can also set it to higher resolutions.
Xmedia Recode video output resolution destroyed
By hibbs in forum Video ConversionReplies: 19Last Post: 21st Oct 2023, 03:27 -
XMedia Recode forces it's own resolution, can't change it
By Lemenus in forum Newbie / General discussionsReplies: 0Last Post: 5th Jul 2020, 08:08 -
XMedia Recode - help please
By aussie43 in forum Video ConversionReplies: 0Last Post: 16th Nov 2019, 19:22 -
Xmedia recode Version:3.4.4.9
By MrAngelus in forum Newbie / General discussionsReplies: 0Last Post: 18th Dec 2018, 14:35 -
XMedia Recode Changing resolution
By hibbs in forum Newbie / General discussionsReplies: 1Last Post: 8th Apr 2018, 23:06
