Hi i was wonderinf if some one could shed some light on what the best CD brand is for a portable VCD player. I have tried imation, Verbatim and Emtec but i get bad results with them all when trying to play them through my Likko J4 discman.....
Any anwsers on this would be gratefully apreciated..
thank You
try fujifilm, you can aslo try using RW.
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
YOSTIE,
There has been some discussion on this same subject about the Napa portable vcd player. If you do a search for Napa, I'm sure you will find an answer for this but according to those posts the problem is with the bit rate not thecd-r that your using. I might be wrong but check it ouy
Hope this helps
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
i would go for datasafe's, my m8s sony system dosnt support cd-r's but it plays the datasafe's no problem, i sell vcd's using datasafe's and never had one complaint yet and all the vcd's sell are for dvd players.
Kev
Best TV brand for DLNA?
By trevytrev in forum Video Streaming DownloadingReplies: 2Last Post: 19th Nov 2014, 09:00 -
By trevytrev in forum Software PlayingReplies: 1Last Post: 29th Dec 2011, 23:58 -
Is VUESCAPE an ok brand?
By yoda313 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 10th May 2009, 19:13 -
Best brand for dvd-r
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 17th Mar 2008, 23:49 -
Best brand of laptop?
By Tbag in forum ComputerReplies: 16Last Post: 7th Feb 2008, 22:59
