My problem is that there is a private stream I want to get but for reasons beyond my control it can take up to a couple minutes for the stream to start, and most if not all software times out first. So what I would like is to find a way to request the stream, but then send dummy stream data (could be just a static image at the proper size) back to the calling program until the desired stream arrives, then switch to sending that stream. I hope that makes sense. Basically I am just looking for some way to keep the calling program from timing out because it's not getting any data. Would prefer a Linux solution (or one that will run in Linux) because I don't run Windows.
use yt-dlp and then --wait-for-video 60
https://www.reddit.com/r/youtubedl/comments/ua2hi3/guys_is_their_a_command_in_ytdlp_to_record_live/ -
Will yt-dlp stream a dummy stream to the client (such as VLC) until the actual stream begins? I always thought yt-dlp was for capturing videos on web sites, not for use with live streaming (at least not in the way I need, where it would pass the live stream to another client but substitute a dummy stream until the real one begins).
yt-dlp can be used to capture live streams, if that's not what your after then you might try streamlink
FFMPEG Save video from rtsp stream to hls stream
By Wisperrio in forum Video Streaming DownloadingReplies: 2Last Post: 26th Aug 2021, 22:38 -
software to trim directly in stream copy?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 17th Apr 2021, 17:17 -
Why does muxing a video stream into a MKV file change that stream?
By 4L7zHhiyQO3Thui6 in forum Video ConversionReplies: 14Last Post: 11th Mar 2021, 03:45 -
.mpd stream to a viewable stream
By anwarica in forum Video Streaming DownloadingReplies: 3Last Post: 9th Jul 2020, 18:55 -
Live Stream Ripping give me a corrupt video file
By Fathom in forum Video Streaming DownloadingReplies: 16Last Post: 8th Aug 2018, 18:01
