Hello,
I am capturing through my Studio PCTV card and am using VirtualDub.
Could you please tell me if I should use the data format RG32 or YUV2.
Normally with RGB32, I am dropping frames but not with YUV2. Should I simply change to YUV2 and be happy or should I struggle to see why I am dropping frame and try to use RGB32.
Does it make a difference between the two. Isn't there a third setting "inbetween" the two.
Regards,
Roh
It's not so much which is better as which colorscheme is used by the hardware (academically I suppose you can argue 32bit RGB is better). Since TV is YUV anyway, you may as well stick with the format that doesn't drop frames.
can't join lossless AVIs - incompatible data format message
By spicediver10191 in forum Video ConversionReplies: 7Last Post: 25th Apr 2012, 08:42 -
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 18:53 -
DebugMode frameserver output: RGB24, RGB32 or YUY2 ?
By codemaster in forum EditingReplies: 8Last Post: 6th Jan 2011, 14:09 -
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 18:18 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 09:00
