Hi, I'm editing a bluray in order to match the sync with a dvd.
I had to cut some scenes, and arrived at a certain frame near the end,
the dvd-r has been edited in a slow-mo way.
I've tried to start the sync by using
Loop(2,0,0)
Loop(2,3,3)
Loop(2,6,6)
etc..
and it works until a certain point, but then it become long and complicated due to frames are very similar and
the slow-mo is not constant, it increases progressively.
so before to replace the BD scene with the DVD upscaled one, which i think is a bad idea, also cause different colors..
I'm wondering if I can act to the bd frames with some simple commands that automatically duplicate the frames in order to reach the lenght of the DVD scene, maintaining a certain sync, not necessarily perfect.
any suggestions?
here below the link of the stakcvertical script encode in which the upsided image is the dvd.
https://www.dropbox.com/s/m5ok7phbsuupzku/StackVertical.mkv?dl=0
Assuming the top half is the full shot from the BD and the bottom half is the full shot with extra frames at the end:
Code:LWLibavVideoSource("StackVertical.mkv") src = last Crop(0,0,-0,height/2) # top half of frame (BD) # 166 frames from the BD need to be reduced to 58 frames from the DVD # so 25 fps needs to be reduced to 25 * 58 / 166 = ~8.735 fps # use SRestore() to preferentially remove blended frames SRestore(frate=8.735).AssumeFPS(25) Overlay(src, last) # so we can see the new BD clip above the original DVD clip Trim(0,57)
is the contrary, or i don't have understand..
I have to edit the BD, adding frames, in order to match the DVD lenght that has more frames as it ìs in slomo.
the stackvertical video top half is the DVD, i have to edit the bottom half part.
my BD script
Code:LoadPlugin("C:\util\MeGUI-2913-64\tools\lsmash\LSMASHSource.dll") V=LWLibavVideoSource("C:\_ - 2 - h264, 1080p24.mkv") V=V.AssumeFPS(25) # original 24p V=V.Loop(0,183495,183550) V=V.Loop(0,183525,185294) V=V.Loop(0,183540,183546) V=V.Loop(0,183553,183760) V=V.Loop(0,183568,183569) A=Trim(V,0,183567) SLOMO=Trim(V,183568,183625) B=Trim(V,183626,0) #SLOMO=SLOMO."WHAT HERE?" V=A++SLOMO++B V=V.crop(0, 20, 0, -20) V=V.Spline36Resize(720,388) #bbmod(0,0,0,0,128,8) Return V Prefetch(7)
the dvd scene is from 183568 and 183733 = 166 frames
the BD scene is from 183568 and 183625 = 58 frames
difference 108 frames.
the 58 frames BD scene must become long 166 frames.
so what i write here?
something like..
.DuplicateEachFrameByX or
.SlomoByX idk..
maybe?
SLOMO=SLOMO.AssumeFPS(num?,den?).ChangeFPS(25)
this last line seems to work well with a value around 9, i'm still trying to figure out which num and den to use...
...oh ok you were right..THX!
SLOMO=SLOMO.AssumeFPS(1450, 166).ChangeFPS(25)
using your fraction it works, (58*25/166)
thx jagabo.Last edited by maudit; 6th Nov 2022 at 08:39.
That's even simpler. ChangeFPS(25.0*166.0/57.0).AssumeFPS(25). If you prefer frame blending use ConvertFPS instead of ChangeFPS. Or for smooth motion use your favorite motion compensated frame rate changer. For example, InterFrame(NewNum=int(25.0*166.0/57.0*1000.0), NewDen=1000, cores=4).AssumeFPS(25). Sample of the last option attached.
I've edited the previous message many times, so i would write this as confirmation.
it appears perfect to me. I continue this way.
thanks for the hint. -
ok, i'm sorry, we had write the comment in the same time, i've read it now,
bd frames are 58 not 57, anyway..
now without using other stuffs which I have to understand yet, like InterFrame..
I've tried to use both
#SLOMO=SLOMO.AssumeFPS(1450, 166).ChangeFPS(25)
#SLOMO=SLOMO.AssumeFPS(1450, 166).ConvertFPS(25)
using ConvertFPS the result is more similar to the DVD, anyway I prefer to use ChangeFPS. it's good enough.
thanks again jag.
edit: oh! you added a sample, now i see.. it looks fine. i suppose it's InterFrame..Last edited by maudit; 6th Nov 2022 at 09:11.
Decimate video with slow motion
By embis2003 in forum RestorationReplies: 1Last Post: 24th Feb 2021, 23:00 -
Slow Motion Video Player??
By DJboutit in forum Newbie / General discussionsReplies: 10Last Post: 13th Nov 2020, 03:36 -
Make a slow motion video at a constant rate
By luciofulci in forum Video ConversionReplies: 7Last Post: 29th Sep 2019, 17:51 -
Adding slow motion - Windows 10 editor
By idontknowwhatimdoing in forum Newbie / General discussionsReplies: 1Last Post: 19th Aug 2019, 11:04 -
Looking For A Media Player Featuring Slow Motion At Less Than 0.25x
By QuesoPotato in forum Software PlayingReplies: 4Last Post: 10th Nov 2017, 10:24
