For the first time I tried using AVS2DVD (v2.42) to author a DVD for North America. I tried changing the 'Zone' from PAL to NTSC but no matter what I tried it would always show up as PAL in the window that comes up when you press 'START'. Is this a bug or is there something I am missing?
Results 1 to 12 of 12
Have you guys thought of having the software do that automatically as well as notifying the user that this is going to be done as a pop-up window? Or come up with an info window saying if NTSC is to be chosen then this is the frame rate and this is the resolution that one needs to change it to? It would help a lot.
The software does the resize, and sets the necessary frame rate, no need to adjust beforehand.
In the preferences, make sure you tick the " save as default " box.
Once these preferences are changed, the project has to be started as new, it won't apply to existing projectsLast edited by davexnet; 5th Nov 2022 at 14:35.
Potplayer preferences window issue
By halserrano in forum Newbie / General discussionsReplies: 0Last Post: 21st Jun 2022, 19:23 -
Converting NTSC->PAL Interlaced DVD Back To NTSC 24FPS???
By SegaSonic91 in forum DVD RippingReplies: 7Last Post: 2nd Oct 2020, 23:55 -
PAL to NTSC
By andy jackson in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2018, 15:53 -
Sound Forge personal preferences folder location
By 55trucker in forum AudioReplies: 4Last Post: 3rd Mar 2018, 16:01 -
fps-conversion: PAL-> NTSC-DVD back!! to PAL (h264/mkv)
By derSimon in forum Video ConversionReplies: 20Last Post: 17th Jan 2018, 08:22
