Hello, I'm trying to playback a surround audio track sent from my PC (using MPC classic with LAV audio as a decoder) to a soundbar (Sony HT-ZF9). The English track which you see below plays perfectly in surround, but not the Japanese one (Flac 5.1).
I tried playing it through my Apple TV 4K and the surround works fine for the Japanese 5.1 Flac track. Any idea what I need to do to reproduce the same playback behavior on my PC? Thank you for any suggestions?
Audio #1
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 2 h 13 min
Bit rate mode : Variable
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Compression mode : Lossless
Title : FLAC 5.1
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Language : Japanese
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 kb/s
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 427 MiB (2%)
Title : AC3 5.1
Language : English
Service kind : Complete Main
Default : No
Forced : No
Encode the flac to ac3.
Edit Video Track Separately From Audio Track in VideoPad
By meandersleut in forum EditingReplies: 0Last Post: 12th Sep 2022, 13:11 -
one audio language option vanished, in a dual audio track IN VLC mdia plyr
By jraju in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2019, 07:43 -
CCD-TR101 Video8 playback no audio, Hi8 playback fine
By erikyater in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Nov 2019, 17:09 -
Remux MPG audio file to add 2nd audio track
By danielmak in forum MacReplies: 0Last Post: 9th Nov 2018, 01:49 -
Avisynth - Audio track longer than video track
By martanius in forum AudioReplies: 4Last Post: 18th May 2018, 03:13
