Thread: Recommended settings for X265
  1. #1
    Member
    Apr 2005
    Posts
    284
    Hi
    I running VidCoder (Have also try handbrake that is build on) and trying to find a good settings for X265
    That settings I have now is very nice but it take to long to convert my files, a 30 min video take over 2 hours.
    I have run this settings before with nice quality and nice speed but did have some problem with some files and I did find the problem.
    I did have to low level in video encoding so I did change it to automatic and now it take a long time.
    I know if I want to have a very good quality it going to take time but it feel I have select to much quality??
    My settings is very simple. That I recording is from my HDTV and it create a video file.
    I then run VidCoder with not so much change settings from default.
    Sizeing I have Automatic and Max height of 720 (I do not need to have the video in full HD)
    Detelecine = Off
    Deinterlace = Decomb, Default, Default
    Denoise = hqdn3d, Medium
    Chroma smooth = Off
    Sharpen = Off
    Colorspace = Off
    Video codec = H.265
    Framerate = Same as source
    Quality = 22 RF
    Tune = None
    Profile = Automatic
    Level = Automatic
    More settings = "ref=5:bframes=5"
    Audio mixdown to Stereo (Most that i recording is already stereo)
    /UPDATE
    I notice that I can run with GPU when I use AMD VCE.
    Now it take less then 4 min but the size is around 3 times bigger then I use CPU instead?
    Member
    Dec 2005
    Posts
    59,234
    Re: Recommended settings for X265
    Try using a faster preset with x265.
    For AMD VCE... If you're using bitrate based encoding specify a lower bitrate (that directly effects the file size). If you're using quality based encoding specify a lower quality to get a smaller file size.
    Member
    Mar 2008
    Posts
    7,600
    Quote Originally Posted by jagabo View Post
    I've had good luck with "fast" preset; read an article somwhere, apparently that's the sweet spot
    Member
    Mar 2011
    Nova Scotia, Canada
    Posts
    1,754
    This is the best guide I've seen, and I've seen it linked to by knowledgeable users ...it says it's for Anime but much modern anime has a lot of CGI so the settings are pretty portable. I've seen a bunch of live action/CGI video using their settings and it looks pretty damn good.
    https://kokomins.wordpress.com/2019/10/10/anime-encoding-guide-for-x265-and-why-to-never-use-flac/
  1. FFMPEG x265 encoding wrong settings for some sources
    By tony95 in forum Video Conversion
    Last Post: 10th Dec 2021, 12:11
  2. Replies: 1
    Last Post: 15th Nov 2020, 10:06
  3. Is my x265 settings are correct?
    By megapro17 in forum Video Conversion
    Last Post: 12th Apr 2020, 08:48
  4. Help with x265 settings
    By ACKR in forum Video Conversion
    Last Post: 1st Apr 2020, 21:03
  5. Recommended HandBrake Settings for BlueRay
    By happyrugger in forum Video Conversion
    Last Post: 3rd Jan 2019, 13:28
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
