hi ive just bought a 4k ultra hd tv and ill be using it mostly for my pc, i have a ryzen 5 5600g processor and i have a gtx 1660 graphics card and its connected with an hdmi lead both ends and when i try to put the resolution higher than 1920x1080p the tv keeps going to a blank screen then back again then says no signal, i tried the native resolution of 3840x2160 and a few others, but once i change it, it just keeps going to a blank screen, and i nearly never got it back to 1920x1080p as it was just flashing the windows screen then back to blank screen again, i had to be quick to get it back, is it just becuase the graphics card cant work on a higher resolution than 1920 or could it be something else i need to do or some other problem, has anyone else experienced this or anything similar?
Thanks for any help
Results 1 to 11 of 11
Both the 1660 and your 4K TV should be able to run at 3840x2160. Make sure you're not trying to run at too high a frame rate. Stick with 60 Hz and below. Try a new HDMI/DP cable.
im prob going to downgrade the graphics driver first i updated it earlier, but think it was before, i tried running at 3840 or higher than 1920
Also make sure you use a hdmi 2.0 cable.
ive read quite alot about it just being a marketing ploy saying the cables are different versions and that all hdmi cables should work and alot of the ones you might buy on the likes of ebay are prob wrognly labeled just to get a sale
Not all cables will work,you need 1.4 for uhd and 2.0 for increased bandwidth,i bought 2.0 just for my uhd tv.
That's not true anymore. Here's a quick table of some HDMI versions and their defined maximum bandwidth:
Some older cables (especially short ones) can successfully carry higher bandwidth signals but to be sure you should use a 2.0 cable for 4K at 60 Hz. The symptoms you are seeing are classic handshake problems -- signs you cable is insufficient for the signal.Code:HDMI Bandwidth Notes Version Gb/s -------------------------------------- 1.0 5 1.3 10 4K up to 30Hz 2.0 18 4K up to 60 Hz 2.1 48 10K up to 120 Hz
well i just went down a few drivers and it still didnt work but it is now worse as it keeps going blank on 1920 now where it was fine before, so i went back to the lastest driver, i also tried 2 different wires and they didnt work at all, all i got was no signal, so i should buy a 4k hdmi cable and it should work properly
ok so ive put it down to 30hz and it seems to be working fine now on 3840, but i will be playing games so ill prob just get a 4k wire anyway to get it upto 60hz but at least ive got it working for now and i dont need to put my fist thru the tv lol
You meant 30hz and 60hz,you would need really thick hdmi cables for mhz.
You should also get the shortest cable that will reach. Don't use a 30 foot cable if a 3 foot cable will reach. Longer runs are more prone to bandwidth and voltage drop problems.
Nvenc GTX 1050 vs GTX 1660
By bizzybody in forum Video ConversionReplies: 2Last Post: 1st Jul 2022, 07:13 -
Using ffmpeg batch file with Nvidia GTX 1650 super
By G4SAQ Russ in forum Video ConversionReplies: 6Last Post: 4th Apr 2021, 12:34 -
Why is the NVIDIA GTX 1660 faster in 8K hevc encoding than the RTX 3070 ?
By Video Grain in forum Video ConversionReplies: 14Last Post: 25th Nov 2020, 18:16 -
I bought a GTX 1080 and I'm disappointed
By gription in forum ComputerReplies: 23Last Post: 1st Mar 2019, 10:45 -
Mini gtx 1070 opinion
By johns0 in forum ComputerReplies: 0Last Post: 19th Apr 2018, 21:22
