A dollar per swab? You gotta be kidding me. I bet 12voltvids does not bother with such posh tools.
Results 421 to 435 of 435
No; extensive usage on several VCRs, never a problem
Hi all, im using colormill for colour corrections but the results have been very hit or miss.
I know that its another very complicated aspect of processing/restoration and that you cant just tell me what to do, but is there a general rule of thumb for the order of what needs to be adjusted? Brightness and contrast should be done last? -
What do you want to achieve? As you say we can't tell you what needs to be adjusted without seeing a picture. A first step may be to check and adjust the white balance. With respect to colors there is a wide range of personal preference. But worse, the source may have irreversible technical flaws, or loose details when converting between color spaces.
Perhaps you upload a sample you are wrapping your head around, and tell us what you like to improve, and collect ideas from members here. -
Its just that the picture is always a bit dull and the colours just seem to be slightly off, on all of my captures.
Blacks or dark colours are normally too dark, when somebody is wearing a suit for example, the lines of the pockets wont be visible.
Brightening up the picture definitely helps but quite often I end up making things look a bit washed out. -
Sounds to me like you would get away with some gamma and levels adjustments. Easy in Avisynth.
In Vdub or VirtualDub2 you may want to play with the filter "gradation curves". You probably have to download this .vdf plugin.
https://forum.videohelp.com/threads/287113-Gradation-Curves-VirtualDub-filter-v1-45
https://neosol.at/vdub/index.html
The tutorials point the way:
https://neosol.at/vdub/tutorial/tutorial.htmlLast edited by Sharc; 28th Apr 2023 at 11:59.
I usually start with adjusting the black and white levels (contrast and brightness, really gain and offset). Then a gamma adjustment (which may then require further contrast/brightness adjustments). Then saturation (saturation usually requires about the same boost as the contrast). Then white balance.
But you may want to look at adjusting your capture device's video processing amp before capturing. Otherwise you may be crushing blacks and brights even before you start filtering/editing.
As noted earlier, adjustments for a specific video sample would be more elucidating. -
Hi, unfortunately I'm new to this forum and can't find how I post a question. So my query is about capturing video from a Betacord Sanyo vtc5150. I have a Click & Convert transfer device, but don't have a cable that will fit the back of the video recorder. The capture device has yellow, red & white female leads, and a 5 pin female lead. The converter is Arcsoft Showbiz DVD 2. Can anyone help please? Thank you, and sorry for hijacking this thread.
The pictures I saw weren't very clear but it looks like that deck has a BNC connector for composite video output. You can use a BNC to RCA adapter. Then use a regular AV RCA cable.
https://www.amazon.com/Monoprice-BNC-Male-Female-Adaptor/dp/B006VK8IEI/ -
Thanks Sharc, Ill read up on that and give it a go over the weekend.
Thanks jagabo, Ill try adjusting things in this order and see if I can get more consistent results.
Ok Ill look into this if the other methods dont work out.
How to set HCEnc for Interlaced VHS capture (or better encoder for VHS)
By Tek03 in forum Authoring (DVD)Replies: 7Last Post: 28th Aug 2022, 21:58 -
Vdub2 VHS C Capture and post processing - advice requested
By sum_guy in forum Capturing and VCRReplies: 98Last Post: 18th Feb 2022, 06:04 -
Digital to Analog Video Conversion & S-VHS Capture with Mac advice needed
By Anonymous4353 in forum Capturing and VCRReplies: 0Last Post: 23rd Jan 2022, 15:49 -
VHS-C Advice
By NY_RRVid in forum Newbie / General discussionsReplies: 24Last Post: 24th Sep 2020, 21:35 -
Out of touch with video capture - USB capture device advice
By Lambchop in forum Capturing and VCRReplies: 7Last Post: 25th Nov 2018, 05:19
