My UHD Blu-Ray copy of Top Gun Maverick arrived and I wanted to append the IMAX Countdown sequence to the beginning of it as in theaters before adding the raw file to my Home Theater PC NAS. I have the MakeMKV rip of the UHD Top Gun disc, and I also have the raw MKV of the IMAX countdown sequence I got online. The problem is that it is not as simple as appending one MKV to the other in MKV Tool Nix as they have different tracks and contents. Is there any way to accomplish this without transcoding the film? If that is required then I'd rather not do it at all since I don't want to lose quality over this.
Thanks.
It's possible to make an mkv that plays other mkvs using "ordered chapters". Not all players support that feature, but it would be the most elegant solution.
UPDATE: I found another way to solve the problem which is to add "Part 1" to the title of the intro sequence and "Part 2" to the movie and it loads each MKV separately, for anyone else who might run into this
Should be able to do it with mkvtoolnix (chapter editor). Might take some time to figure out though!
Need to Append JPG to MP4 file
By Novice20 in forum Newbie / General discussionsReplies: 9Last Post: 30th Oct 2022, 08:35 -
Append continuations of the same configuration + volume change?
By DynVec in forum EditingReplies: 5Last Post: 2nd Aug 2022, 13:53 -
How to batch resize AND append multiple videos in Avidemux?
By savvyguy in forum Newbie / General discussionsReplies: 6Last Post: 28th Jul 2021, 18:00 -
MKVToolnix Muxing Append Error: Can't Append File to Itself
By koberulz in forum Newbie / General discussionsReplies: 2Last Post: 4th Sep 2019, 15:58 -
Avidemux cant append videos properly
By supercain in forum EditingReplies: 10Last Post: 13th Oct 2018, 20:39
