Hi, I've never had any issues with HV40 but at the weekend I shot around 40 mins of footage, but when I got home and played back only the first two mins play after which there is no times displayed on the blank blue playback screen. If I fast forward there are various occurrences where there is time info flashes up. When I press play at those intervals nothing is displayed and the time doesn't progress. When I press stop the time updates to account for the elapsed period.
I was messing with cine mode which perhaps wrecked something - I was in HDV mode throughout.
Is there any way I can salvage my footage? Is it likely to be a faulty tape? If I record.aomething at the end of tape it seems to be fine.
The only other thing to add is that I noticed after about 20mins of recording that the "counter" reset to zero and the timing started again. I'm not sure if this was related to doing a "scene review" of the last recording but something odd was definitely going on.
Any info would be great.
I’m watching this…I have the HV-30 (low miles), these are aging and I use mine for transfer.
i'd recommend not changing any camcorder settings while recording. always try to roll-in/roll-out 5 seconds before and after action. tape may be re-usable try recording over from the beginning. when i open a new(old stock now) tape i fast forward to the end and rewind before recording just to loosen it up.
maybe its due dirty drum issue.
have you ever tried to play this tape in another HDV machine?
Screen Recording Problem!
By ten in forum Software PlayingReplies: 9Last Post: 9th Jan 2022, 12:26 -
AverMedia c285 recording problem
By wkw57 in forum Capturing and VCRReplies: 9Last Post: 28th Jul 2021, 03:26 -
HDVsplit 0.77 beta does not recognize Canon Vixia HV40 DV/HDV camcorder
By RAZ32 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 30th Jun 2020, 20:57 -
Recording VHS with VirtualDub problem.
By SJ-M- in forum Capturing and VCRReplies: 1Last Post: 25th Feb 2020, 09:18 -
Need to clean heads on Canon Vixia hv40 - how do you access them?
By CaptainJack in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 31Last Post: 3rd Jul 2019, 01:54
