I am highly suspicious of video camera footage being tampered with and I cannot afford a real forensic analysts and I think they’re often compromised. I was wondering if when sending a video to media info is there any aspects to their analyzations that a sure sign that footage was maliciously edited? Please excuse my ignorance with computers. I am just learning. Thank you
Closed Thread
Results 1 to 30 of 41
Mediainfo gives you basic parameters of the video which it mostly derives from reading the header. It does not do the kind of deep analysis you are looking for.
What kinds of artifacts or clues are you seeing that lead you to believe your files are being manipulated? Do you have the original files for comparison?
I agree MediaInfo only shows some header info and basically anything it shows could be changed.
If you don't have an original footage to compare it to there is nothing you can do about it, At least not something the community here can do without an original and tempered with samples, I see threads like this pop up from time to time but unfortunately even in the deepfake era and AI rendering there are limits to what a human being can do with such tools especially when there is no samples at hand, If all what you need to prove is that it was tempered with and case dismissed, I think you have done that already.
Thank you for taking your time to explain what you did. Issues like a cameras specs list frames per second at 30 yet the video has a range from 15-600 fps. The problem is that I’m not at all computer literate like youngsters but I’m learning. I’m going to send a few more pics. I don’t know if it will help. Also, there are 2 versions of the video. One video is date and time stamped and the other isn’t. On the metadata I included I posted the original hashcode is the same with the first line of each of the 3 streams but then each of three tines have several hoaevofe.
Thank you in advance.
Yeah but your desktop computer or someone else's? How would the video go through some one else's computer. Why would someone want to tamper with the footage? If you think that someone could tamper with video from your own pc, I think you would need some help, and by that I don't mean video help.
Oh well, send mediainfo results in that case. Unless the video has been reencoded it could maybe be found. Also what kind of tampering is it?
Can you tell by this block if the metadata connected is edited?
Header 00 00 00 20 66 74 79 70 69 73 6F 6D 00 00 02 00 69 73 6F 6D 69 73 6F 32 61 76 63 31 6D 70 34 31 00 38 D9 D2 6D 6F 6F 76 00 00 00 6C 6D 76 68 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 E8 00 3F EA 17 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
Complete name :
Format : MPEG-4
Format profile : Base Media
File size : 794 MiB
Duration : 1 h 9 min
Overall bit rate : 1 591 kb/s
Writing application : Lavf56.40.100
Video
Format : AVC
Format profile : High
Format level : 5
Format settings, CABAC : Yes
Format settings, Referenc : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Bit rate : 1 489 kb/s
Width : 864 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.766 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.121
Stream size : 743 MiB (94%)
Codec configuration box : avcC
Audio
Format : AAC LC
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 96.0 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 24.0 kHz
Frame rate : 23.438 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 47.3 MiB (6%)
Default : Yes
Alternate group : 1
<?xml version="1.0" encoding="UTF-8"?>
<MediaInfo
xmlns="https://mediaarea.net/mediainfo"
xmlns
si="http://www.w3.org/2001/XMLSchema-instance"
xsi
chemaLocation="https://mediaarea.net/mediainfo https://mediaarea.net/mediainfo/mediainfo_2_0.xsd"
version="2.0">
<creatingLibrary version="22.09" url="https://mediaarea.net/MediaInfo">MediaInfoLib</creatingLibrary>
<media ref="_202111071550_G210_214251264 2(1).mp4">
<track type="General">
<VideoCount>1</VideoCount>
<AudioCount>1</AudioCount>
<FileExtension>mp4</FileExtension>
<Format>MPEG-4</Format>
<Format_Profile>Base Media</Format_Profile>
<CodecID>isom</CodecID>
<CodecID_Compatible>isom/iso2/avc1/mp41</CodecID_Compatible>
<FileSize>832888861</FileSize>
<Duration>4188.695</Duration>
<OverallBitRate>1590737</OverallBitRate>
<FrameRate>29.766</FrameRate>
<FrameCount>124678</FrameCount>
<StreamSize>3725826</StreamSize>
<HeaderSize>3725818</HeaderSize>
<DataSize>829163043</DataSize>
<FooterSize>0</FooterSize>
<IsStreamable>Yes</IsStreamable>
<Encoded_Application>Lavf56.40.100</Encoded_Application>
</track>
<track type="Video">
<StreamOrder>0</StreamOrder>
<ID>1</ID>
<Format>AVC</Format>
<Format_Profile>High</Format_Profile>
<Format_Level>5</Format_Level>
<Format_Settings_CABAC>Yes</Format_Settings_CABAC>
<Format_Settings_RefFrames>1</Format_Settings_RefFrames>
<Format_Settings_GOP>M=1, N=30</Format_Settings_GOP>
<CodecID>avc1</CodecID>
<Duration>4188.602</Duration>
<BitRate>1488966</BitRate>
<Width>864</Width>
<Height>480</Height>
<Sampled_Width>864</Sampled_Width>
<Sampled_Height>480</Sampled_Height>
<PixelAspectRatio>1.000</PixelAspectRatio>
<DisplayAspectRatio>1.800</DisplayAspectRatio>
<Rotation>0.000</Rotation>
<ColorSpace>YUV</ColorSpace>
<ChromaSubsampling>4:2:0</ChromaSubsampling>
<BitDepth>8</BitDepth>
<ScanType>Progressive</ScanType>
<StreamSize>779585670</StreamSize>
<extra>
<CodecConfigurationBox>avcC</CodecConfigurationBox>
</extra>
</track>
<track type="Audio">
<StreamOrder>1</StreamOrder>
<ID>2</ID>
<Format>AAC</Format>
<Format_AdditionalFeatures>LC</Format_AdditionalFeatures>
<CodecID>mp4a-40-2</CodecID>
<BitRate_Mode>CBR</BitRate_Mode>
<BitRate>96000</BitRate>
<Channels>2</Channels>
<ChannelPositions>Front: L R</ChannelPositions>
<ChannelLayout>L R</ChannelLayout>
<SamplesPerFrame>1024</SamplesPerFrame>
<SamplingRate>24000</SamplingRate>
<SamplingCount>100528680</SamplingCount>
<FrameRate>23.438</FrameRate>
<FrameCount>98173</FrameCount>
<Compression_Mode>Lossy</Compression_Mode>
<StreamSize>49577365</StreamSize>
<StreamSize_Proportion>0.05952</StreamSize_Proportion>
<Default>Yes</Default>
<AlternateGroup>1</AlternateGroup>
</track>
</media>
</MediaInfo>
creatingLibrary": {
"name": "MediaInfoLib",
"version": "22.09",
"url": "https://mediaarea.net/MediaInfo"
"media": {
"@ref": "_202111071550_G210_214251264 2(1).mp4",
"track": [
"@type": "General",
"VideoCount": "1",
"AudioCount": "1",
"FileExtension": "mp4",
"Format": "MPEG-4",
"Format_Profile": "Base Media",
"CodecID": "isom",
"CodecID_Compatible": "isom/iso2/avc1/mp41",
"FileSize": "832888861",
"Duration": "4188.695",
"OverallBitRate": "1590737",
"FrameRate": "29.766",
"FrameCount": "124678",
"StreamSize": "3725826",
"HeaderSize": "3725818",
"DataSize": "829163043",
"FooterSize": "0",
"IsStreamable": "Yes",
"Encoded_Application": "Lavf56.40.100"
"@type": "Video",
"StreamOrder": "0",
"ID": "1",
"Format": "AVC",
"Format_Profile": "High",
"Format_Level": "5",
"Format_Settings_CABAC": "Yes",
"Format_Settings_RefFrames": "1",
"Format_Settings_GOP": "M=1, N=30",
"CodecID": "avc1",
"Duration": "4188.602",
"BitRate": "1488966",
"Width": "864",
"Height": "480",
"Sampled_Width": "864",
"Sampled_Height": "480",
"PixelAspectRatio": "1.000",
"DisplayAspectRatio": "1.800",
"Rotation": "0.000",
"ColorSpace": "YUV",
"ChromaSubsampling": "4:2:0",
"BitDepth": "8",
"ScanType": "Progressive",
"StreamSize": "779585670",
"extra": {
"CodecConfigurationBox": "avcC"
"@type": "Audio",
"StreamOrder": "1",
"ID": "2",
"Format": "AAC",
"Format_AdditionalFeatures": "LC",
"CodecID": "mp4a-40-2",
"BitRate_Mode": "CBR",
"BitRate": "96000",
"Channels": "2",
"ChannelPositions": "Front: L R",
"ChannelLayout": "L R",
"SamplesPerFrame": "1024",
"SamplingRate": "24000",
"SamplingCount": "100528680",
"FrameRate": "23.438",
"FrameCount": "98173",
"Compression_Mode": "Lossy",
"StreamSize": "49577365",
"StreamSize_Proportion": "0.05952",
"Default": "Yes",
"AlternateGroup": "1"
This is the chain of custody of the footage ..to me it appears by the number of times it went here and there that the footage was being edited.
https://acrobat.adobe.com/link/review?uri=urn:aaid
cds:US:988333d8-558e-4ee1-b090-7dfd28ace948
This is dash camera footage that was accessed by 2 officers for 6 days after the arrest. Appears a lot of transferring and moving etc. lots of different hash codes. To me it appears there was malicious tampering
13 Nov 2021
Viewed
Username:
Occurred At: 2021-11-13T13:56:17.347Z
Source: 10.35.146.127
Event ID: 00:1d:96:00:c7:49-214251264
Source IP: 10.35.146.127
Source Type: EL Web
Event Key: 34b249bf-93d3-4ba1-8267-6cb56b6a1233
Triggered By: Client
Category: Other-Miscellaneous
Vehicle/Device: G2-10
Officer Name:
· · 8 Nov 2021
Move
Username: ELWeb Job Queue
Occurred At: 2021-11-08T23:58:12.632Z
Source:
Destination: \\spbedprapgs1001\video.storage.final$\34b249bf93d 34ba182676cb56b6a1233
Source:
Source IP: 10.35.146.9
Destination Type: Transfer
Triggered By: ELWeb Job Queue
Officer Name:
Start Time: 2021-11-08T23:57:29.000Z
Stop Time: 2021-11-08T23:58:12.000Z
· · 8 Nov 2021
Viewed
Username:
Occurred At: 2021-11-08T01:44:27.575Z
Source: 10.35.146.103
Source IP: 10.35.146.103
Source Type: EL Web
Officer Name:
· · 8 Nov 2021
Viewed
Username:
Occurred At: 2021-11-08T01:11:06.862Z
Source Type: EL Web
Officer Name:
· · 8 Nov 2021
Viewed
Username:
Occurred At: 2021-11-08T00:16:48.742Z
Source Type: EL Web
Officer Name:
· · 7 Nov 2021
Imported
Username: System
Occurred At: 2021-11-07T23:59:19.310Z
Source:
Destination: \\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233
Source:
Source Type: Import Service
Destination IP: 10.35.146.9
Destination Type: Final Storage
Officer Name:
Start Time: 2021-11-07T20:50:40.000Z
Stop Time: 2021-11-07T21:59:44.000Z
Complete: True
Retention Period: Indefinitely
Imported
Camera View
Original
Hashcode Original
Hashcode Verified
Front
tick214264689-tick214273067-video1.mp4
4ae26cd84205af2025514290182adf76
True
Front
tick214264689-tick214273067-video1.vtt
f4b35376dc92fbd98c6cb71150e00959
True
Front
tick214264689-tick214273067-video1.json
16cce6949c0eb94b0d9dae9a000d0ffe
True
Secondary
tick214264689-tick214273067-video2.mp4
f985df90341f65b275be90eeefcad9a1
True
Secondary
tick214264689-tick214273067-video2.vtt
True
Secondary
tick214264689-tick214273067-video2.json
08979dde665f5dcf404b672d1a60adc7
True
Secondary
tick214264689-tick214273067-video3.mp4
a0946f990948995bdd2bcead1cb9467e
True
Secondary
tick214264689-tick214273067-video3.vtt
True
Secondary
tick214264689-tick214273067-video3.json
b15c4863e9d55d313268bcd57bd35094
True
· · 7 Nov 2021
Move
Username: Import
Occurred At: 2021-11-07T23:57:06.681Z
Source:
Source: spbedprapgs1001
Triggered By: ELWeb Import
Officer Name: Unknown
Start Time: 2021-11-07T23:57:06.000Z
Stop Time: 2021-11-07T23:57:06.000Z
Files Transferred
Original
Hashcode Original
Hashcode Verified
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214273052-tick214273067-video3.wgv
28a56d1bd26d05d8459ed98cbc211e34
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214266619-tick214267446-video1.wgv
6c60f3b7f20a6890d169d075e9586a26
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214270590-tick214271411-video3.wgv
09ac74937f3150d550b3cf2b97289528
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214271411-tick214272232-video3.wgv
81f7a64af655c1f74d7d0c94536b3c97
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214272232-tick214273052-video3.wgv
eef0f9542f50d0ddf233f1a23256c809
True
· · 7 Nov 2021
Move
Username: Import
Occurred At: 2021-11-07T23:56:22.557Z
Source:
Source:
Start Time: 2021-11-07T23:56:22.000Z
Stop Time: 2021-11-07T23:56:22.000Z
Files Transferred
Original
Hashcode Original
Hashcode Verified
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214264689-tick214264845-video3.wgv
c87e2b1f11feb8c1bf23dc973d2ce333
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214264845-tick214265665-video3.wgv
76012d87bb9519cafb885d69628c808b
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214268718-tick214269399-video2.wgv
76553b741c215e47658505fe7422676f
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214268949-tick214269770-video3.wgv
8e83f9a9452a9bbd86f7e3505f44d0a3
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214269399-tick214270081-video2.wgv
3dbf79c9c3cb4b6a5308cf99e66eb775
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214265665-tick214266486-video3.wgv
cf8d41c5bae4153003fbccf72a7ed5ca
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214266674-tick214267355-video2.wgv
9a960cf5d6dc408558b679b99775ea2e
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214265311-tick214265992-video2.wgv
4518ee8aef5282292d2fcce62c48e371
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214265992-tick214266674-video2.wgv
d6c3a98e7db74276f0a809aa65fe1170
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214266486-tick214267307-video3.wgv
e2ade2fc7d56b06aabe62eecee7048dc
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214270081-tick214270762-video2.wgv
e934e32fb25c31a9767ed7c47af2462f
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214267307-tick214268129-video3.wgv
e44bae55251a27b8d2d283e8d922bef2
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214272125-tick214272806-video2.wgv
1d7e5d0e8e4215281b8ac1cdb8c4ad96
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214272806-tick214273067-video2.wgv
9b5a51472ac14042c01dbf7475df59b9
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214264689-tick214265311-video2.wgv
decc09b10433e8c077a9748f14186b83
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214269770-tick214270590-video3.wgv
74dcd827525cf5542657668d3caebd7b
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214267355-tick214268037-video2.wgv
81ad54e9553ff1921f0a5a5aae2793ae
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214268129-tick214268949-video3.wgv
3fed3c46a6e968f966de8311a95379e8
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214271443-tick214272125-video2.wgv
7f15589f9e2ec24196386645986f2730
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214264967-tick214265792-video1.wgv
28f01d3a26d0bbcb63d2cfe8a19d98bf
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214270762-tick214271443-video2.wgv
5300f40d2902e1e45b9275104a751cb6
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214270745-tick214271570-video1.wgv
03599fa763574f5378f7a27221596b7c
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214272395-tick214273067-video1.wgv
fa537533cf53d19ea84a3443c87bb3f3
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214267446-tick214268271-video1.wgv
f05466f944376f03af487f7080dddf4d
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214269920-tick214270745-video1.wgv
be7d2e01155763fe33977e7a7ef390f2
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214271570-tick214272395-video1.wgv
9f4e7ae550d574f09aaab093840b21f9
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214265792-tick214266619-video1.wgv
ab56b941e09c6b85a88888a8c5e8fe72
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214268271-tick214269095-video1.wgv
908be939d4a24c51cafad05603d90569
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214269095-tick214269920-video1.wgv
bc67ba6f9728903bee9c4f0b77e115fa
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214268037-tick214268718-video2.wgv
5d391be32c303a6ada7a935385caec23
True
· · 7 Nov 2021
Uploaded
Occurred At: 2021-11-07T23:55:25.441Z
Source:
Destination:
Source:
Source Type: Wireless
Destination:
Destination Type: Import Service
Officer Name:
Start Time: 2021-11-07T23:55:25.000Z
Stop Time: 2021-11-07T23:56:03.000Z
Uploaded
Camera View
Original
Hashcode Original
Hashcode Verified
1
tick214264689-tick214264967-video1.wgv
f507ef633447298cf0f1f6d96e361848
True
1
True
1
True
1
True
1
True
1
True
1
True
1
True
1
True
1
True
1
True
2
True
2
True
2
True
2
True
2
True
2
True
2
True
2
True
2
True
2
True
2
True
2
True
2
True
3
True
3
True
3
True
3
True
3
True
3
True
3
True
3
True
3
True
3
True
3
True
3
True
· · 7 Nov 2021
Uploaded
Occurred At: 2021-11-07T23:55:24.269Z
Source: G2-10
Destination:
Source: G2-10
Source IP: 10.35.146.248
Source Type: VISTA/4RE
Destination:
Destination Type: DVR Communications Service
Officer Name:
Event Size: -746586112
Files Uploaded
Camera View
Original
Hashcode Original
Hashcode Verified
Stream 1
True
Stream 1
True
Stream 1
True
Stream 1
True
Stream 1
True
Stream 1
True
Stream 1
True
Stream 1
True
Stream 1
True
Stream 1
True
Stream 1
True
Stream 2
True
Stream 2
True
Stream 2
True
Stream 2
True
Stream 2
True
Stream 2
True
Stream 2
True
Stream 2
True
Stream 2
True
Stream 2
True
Stream 2
True
Stream 2
True
Stream 2
True
Stream 3
True
Stream 3
True
Stream 3
True
Stream 3
True
Stream 3
True
Stream 3
True
Stream 3
True
Stream 3
True
Stream 3
True
Stream 3
True
Stream 3
True
Stream 3
True
· · 7 Nov 2021
Move
Username: Import
Occurred At: 2021-11-07T23:47:59.426Z
Source:
Destination: \\\video.storage$\34b249bf93d34ba182676cb56b6a1233
Start Time: 2021-11-07T23:47:59.000Z
Stop Time: 2021-11-07T23:47:59.000Z
Files Transferred
Original
Hashcode Original
Hashcode Verified
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214264689-tick214273067.xml
e29db6b935ce5c1e53a05963b9eb1d14
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214264689-tick214264967-video1.wgv
True
\\spbedprapgs1001\video.storage$\34b249bf93d34ba18 2676cb56b6a1233\tick214264689-tick214273067.mtd
edf433db4f9979809e33f13712a668e8
True
7 Nov 2021
Created
Occurred At: 2021-11-07T20:50:40.000Z
Source: G2-10
Source: G2-10
Officer Name:
Files Created
Camera View
Original
Hashcode Original
Metadata
Stream 1
Stream 1
Stream 1
Stream 1
Stream 1
Stream 1
Stream 1
Stream 1
Stream 1
Stream 1
Stream 1
Stream 2
Stream 2
Stream 2
Stream 2
Stream 2
Stream 2
Stream 2
Stream 2
Stream 2
Stream 2
Stream 2
Stream 2
Stream 2
Stream 3
Stream 3
Stream 3
Stream 3
Stream 3
Stream 3
Stream 3
Stream 3
Stream 3
Stream 3
Stream 3
Stream 3
Like I said, I am not at all educated in this stuff. I really appreciate your time. If this isn’t what you looking for let me know
Also, I realized that this footage has a file that appears to be temporary status like. Again, I apologize for not be educated
<MediaInfo
xmlns
xsi
version="2.0">
<media ref="_202111071550_G210_214251264 5.MP4">
<FileExtension>MP4</FileExtension>
<Format_Profile>QuickTime</Format_Profile>
<CodecID>qt </CodecID>
<CodecID_Version>0000.00</CodecID_Version>
<CodecID_Compatible>qt </CodecID_Compatible>
<FileSize>1098813998</FileSize>
<Duration>4188.666</Duration>
<OverallBitRate>2098642</OverallBitRate>
<FrameRate>29.970</FrameRate>
<FrameCount>125539</FrameCount>
<StreamSize>2730895</StreamSize>
<HeaderSize>2722584</HeaderSize>
<DataSize>1096091414</DataSize>
<Encoded_Date>UTC 2022-10-30 23:10:33</Encoded_Date>
<Tagged_Date>UTC 2022-10-30 23:11:33</Tagged_Date>
<Encoded_Library>Apple QuickTime</Encoded_Library>
<Encoded_Library_Name>Apple QuickTime</Encoded_Library_Name>
<extra>
<com_apple_photos_originating_signature>AQlDI0y8F8 veD+SxiTzSVTYpyTGq</com_apple_photos_originating_signature>
<com_apple_quicktime_creationdate>2022-06-28T19:28:50-04:00</com_apple_quicktime_creationdate>
</extra>
</track>
<ID>2</ID>
<Source_Duration>4188.699</Source_Duration>
<BitRate>1998665</BitRate>
<Width>1280</Width>
<Height>240</Height>
<Sampled_Width>1280</Sampled_Width>
<Sampled_Height>240</Sampled_Height>
<DisplayAspectRatio>5.333</DisplayAspectRatio>
<FrameRate_Mode>VFR</FrameRate_Mode>
<FrameRate_Minimum>29.940</FrameRate_Minimum>
<FrameRate_Maximum>30.010</FrameRate_Maximum>
<StreamSize>1046506732</StreamSize>
<Source_StreamSize>1046514546</Source_StreamSize>
<Title>Core Media Video</Title>
<extra>
</extra>
</track>
<ID>1</ID>
<Duration>4188.606</Duration>
<Source_Duration>4188.648</Source_Duration>
<SamplingCount>100526544</SamplingCount>
<FrameCount>98171</FrameCount>
<Source_FrameCount>98172</Source_FrameCount>
<StreamSize>49576371</StreamSize>
<StreamSize_Proportion>0.04512</StreamSize_Proportion>
<Source_StreamSize>49576860</Source_StreamSize>
<Source_StreamSize_Proportion>0.04512</Source_StreamSize_Proportion>
<Title>Core Media Audio</Title>
<extra>
<Source_Delay>45</Source_Delay>
<Source_Delay_Source>Container</Source_Delay_Source>
</extra>
</track>
</media>
</MediaInfo>
18:48:45.674 I mainwindow.cpp 121 Starting "SanDiskUpdate" "6.3.10W"
18:48:45.674 I mainwindow.cpp 122 Date "07.07.2022 18:48"
18:48:45.674 I mainwindow.cpp 123 USB Path: "F:/"
18:48:50.316 I mainwindow.cpp 129 "App Path C:/Users/Jordon/AppData/Local/Temp/liteUpdater"
18:48:50.316 D mainwindow.cpp 134 trying lock file "F://PrivateAccess Settings/lock"
18:48:50.316 I mainwindow.cpp 202 "C:/Users/Jordon/AppData/Local/Temp/liteUpdater/PrivateAccess_win.exe" "F:/PrivateAccess_win.exe"
18:48:50.317 I mainwindow.cpp 203 "C:/Users/Jordon/AppData/Local/Temp/liteUpdater/PrivateAccess_linux" "F:/PrivateAccess_linux"
18:48:50.317 I mainwindow.cpp 204 "C:/Users/Jordon/AppData/Local/Temp/liteUpdater/PrivateAccess_mac.app" "F:/PrivateAccess_mac.app"
18:48:50.318 I mainwindow.cpp 253 wildcard rename "F:/SanDiskSecureAccessV3.01_win.exe" to "F:/PrivateAccess_win.exe"
18:48:50.319 E mainwindow.cpp 256 remove of "F:/PrivateAccess_win.exe" failed
18:48:50.331 I mainwindow.cpp 283 wildcard match found correct entry
18:48:50.332 I mainwindow.cpp 318 windows executable detected, upgrading...
18:48:50.332 D fileutils.cpp 71 FileUtils::removeFile "F:/PrivateAccess_win.exe"
18:48:52.285 I mainwindow.cpp 331 Copy "C:/Users/Jordon/AppData/Local/Temp/liteUpdater/PrivateAccess_win.exe" succesful
18:48:54.288 I mainwindow.cpp 408 starting executable "F:/PrivateAccess_win.exe" ("-dd")
18:48:58.533 I mainwindow.cpp 421 shutting down
How to downlaod videos from learnyst videos
By vikas- in forum Video Streaming DownloadingReplies: 8Last Post: 4th Apr 2022, 00:56 -
How Merge 1 Video to 100 Videos (Intro + Multiple Main Videos) help
By Squid Ward in forum EditingReplies: 0Last Post: 4th Sep 2020, 11:27 -
Why are my videos being interlaced?
By magnu in forum Video ConversionReplies: 4Last Post: 9th Aug 2020, 15:29 -
What is the best way to upscale videos.
By Felow in forum Video ConversionReplies: 15Last Post: 9th Jan 2020, 16:00 -
How do I rip videos from v.qq?
By Rex in forum Video Streaming DownloadingReplies: 12Last Post: 4th Nov 2018, 09:01
