Hi,
I would like to create a VTT file from ffmpeg to create a thumbnail tooltip for JW Player.
So far I found this 8 years old answer to be quite reliable https://stackoverflow.com/questions/20022006/generate-all-the-files-vtt-sprite-for-the...options-of-jwp
There are some problems though:
- He doesn't explain how to generate the VTT file at the end (6.), how do I do it with ffmpeg?
- It would be possible to blend all these different operation in a single bash command eventually, to do this process for all multiple files inside a folder? How?
- His python script gives me syntax error and also not much clear to me how to use it. If possible I would like to use bash script on Windows with cygwin or Powershell to automate this operation
The easiest way is to open a text editor and simply enter the desired entries in the following format and then save it as .txt.
After that you simply rename the text file extension from .txt to .vtt.WEBVTT
00:00:49.880 --> 00:00:52.970
Check, please.
00:00:53.090 --> 00:00:55.260
Look, Daddy, a volcano.
00:00:55.380 --> 00:00:57.470
It's very pretty.
00:00:57.510 --> 00:00:59.640
All right. We're going. Mommy's waiting.
00:00:59.720 --> 00:01:01.720
Daddy, please. Just one more minute. -
Is there a way to do it with a software? As said I do not need it for subtitles but for thumbnails. Getting the coordinate over an image, I don't even know where to start manually...
How do I save the vtt with a custom filename instead of the input.mp4 filename? -o is only a suffix
Get VTT fragments in one vtt or srt file, MPD not m3u8
By maronsca in forum Video Streaming DownloadingReplies: 13Last Post: 27th Aug 2022, 10:02 -
need help to download m3u8(.vtt) - .HAR file available
By Hamwi1985 in forum Video Streaming DownloadingReplies: 4Last Post: 7th Jul 2021, 06:31 -
can any one help me to open this subtitle file vtt ? i need to download
By alsalam4man in forum Video Streaming DownloadingReplies: 4Last Post: 22nd Mar 2021, 10:16 -
ffmpeg command for disable vtt
By Alberto78 in forum Video ConversionReplies: 0Last Post: 22nd Apr 2020, 04:12 -
Create batch file for ffmpeg to increment the file output
By Bassquake in forum Video ConversionReplies: 2Last Post: 25th Nov 2019, 05:03
