What types of cards and software are needed to get my PC to pull in
channels I can view on my PC?
For basic TV viewing any TV tuner card should work. For more advanced features (Think TiVo) you might want to look at the ATI Radeon All in Wonder or the nVidia Personal Cinima packages. These packages give you the ability to pause live TV, capture for later viewing, video editing, etc. Please note that you will need to use a converter box for viewing the digital cable signals.
To view digital cable you have to run your cable from the cable box then to the pc. Your t.v. card set to channel 3. To view the channel you want go back and use the cable box as your turner. Now if you just hook up thru your cable only then you can use your t.v. card as your tuner. Just remember channels 0-99 are analog they are not digital.
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 15:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 20:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 10:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 08:04 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 21:34
