I have this simple script I've started with:
What do the RemoveDirtMC parameters mean? What does the 20 refer to and what is the significance of the 'false' value? I haven't found an explanation, or if I have, I didn't understand it.Code:FFMPEGSource2("file_for_dirt_removal.mp4", atrack=1) ConvertToYV12(matrix="rec709") RemoveDirtMC(20, false
thanks,
babag
The first (aside from the clip) argument is the strength of the filter. The higher you set it the more "dirt" is removed. If you set it to high you will remove detail too. The second argument is whether to work only on the greyscale channel. If set to true only the luma will be processed. If false the chroma will be processed too.
thanks, jagabo! is there a defined range within which the strength parameter works? something like 0-100 or 0-255?
thanks again,
babag -
I don't know what the full range is but useful values are from about 0 to 50. You might sometimes go higher for still shots.
do you know to what extent image size has an affect on the strength? would i use larger numbers for 4k than sd?
I believe the filter is less effective with higher resolutions. So you may have to use higher numbers for 4K.
thanks! it's been interesting testing. should continue to be so. current tests are on hd material but the originals of that material are 2880x2160 so we'll see.
RemoveDirtMc won't work in Avisynth+
By TeNSoR in forum Newbie / General discussionsReplies: 14Last Post: 12th Feb 2019, 08:13 -
RemoveDirtMC Error message
By TeNSoR in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2018, 09:03
