hi, i'm using 3 scripts:
bluray
DVDDVD=FFVideoSource("C:\\makemkv\B1_t00_track1_[eng].mkv", fpsnum=25, fpsden=1, threads=1)
DVDTrim=DVD.Trim(0,4854)
DVDTrim=DVDTrim.crop(22, 4, -22, -2).bbmod(2,2,2,2,128,8).Spline36Resize(1436,852).A ddBorders(0, 114, 0, 114, $000000)
V=FFVideoSource("C:\1080p Blu-ray Remux_track1_[spa].mkv", fpsnum=24, fpsden=1, threads=1)
V=V.AssumeFPS(25).crop(242, 0, -242, 0).bbmod(0,0,2,2,128,8)
V=V.Loop(0,0,4268)
V=DVDTrim+V
#~ V=V.Loop(2,5304,5304)
#~ V=V.Loop(2,12517,12517)
#~ V=V.Loop(62,12519,12519)
return V.Spline36Resize(672,398)
Prefetch(7)
V=FFVideoSource("C:\\B1_t00_track1_[eng].mkv", fpsnum=25, fpsden=1, threads=1)
A=FFAudioSource("C:\\B1_t00.mkv",3)
# SAR 64:45
AudioDub(V,A)
Waveform(window=4, zoom=8, under=true)
and STACKVERTICAL
where i receive the error message: stackvertical: image widths don't matchDVD=Import("C:\B1_t00_track1_[eng].mkv.avs").FFInfo(cfrtime=false,vfrtime=false,colo rspace=false,colorrange=false,cropping=false,sar=f alse, version=false, frametype=false)
BD=Import("C:\1080p Blu-ray Remux_track1_[spa].mkv.avs").FFInfo(cfrtime=false,vfrtime=false,colo rspace=false,colorrange=false,cropping=false,sar=f alse, version=false, frametype=false)
StackVertical(DVD,BD)
but images have the same widths, I can't get where the error is.
can someone please help me?
You're waveform() settings increase the frame height but that should still allow vertical stacking. Verify the frame sizes in your stacking script.
yep waveform does not matter.. only widths matter with stackvertical,,, anyway
..thanks i didn't think to verify sizes in the the stacking script..
in fact there's a problem, the stackvertical script "return DVD" is 720x576
but can't get why... the dvd script image is correct, is 672,398 like the bd script is.
https://www.dropbox.com/sh/q2909c6aiwcridb/AAAn7Qz4YnNLI-qDD1T147aea?dl=0
EDIT: ok I got it, somehow the 2 scipts DVD variables interfered each other, so I just changed
DVD to DVDa in the BD script and all works now.Last edited by maudit; 26th Oct 2022 at 16:40.
Keep in mind that importing an AVS script is closer to cutting and pasting the text of that script. If you want the video output of that script use AviSource() to "import" it, not import().
Getting 2 videos to match?
By ChasVideo in forum EditingReplies: 5Last Post: 12th Nov 2021, 05:50 -
Resing one video to match another?
By ChasVideo in forum EditingReplies: 2Last Post: 9th Nov 2021, 17:32 -
"The number of audio channels don't match"
By LucianoTheWindowsFan in forum EditingReplies: 1Last Post: 2nd Nov 2020, 09:31 -
GoPro 3D L+R files don't match in Cineform Studio
By Dino Soar in forum Newbie / General discussionsReplies: 4Last Post: 9th Sep 2018, 06:45 -
Splitting into 3, editing 1, can't rejoin bc private codec data don't match
By Travillion in forum EditingReplies: 57Last Post: 8th Aug 2018, 15:34
