HI i have been trying to make a short music mpeg VCD to work on my samsung 709 player. I have done many attempts and have followed the tutorial and guide but the prob i get is that right at the end of the VCD it pixelates roughly in the same place everytime but is fine on my pc Here is some info that might help,
Holly Valance -- kiss kiss mpeg
352x288
25,000 fps
141 kb/s (average bit rate)
The Template i use in TMPGEnc. is VideoCD PAL as the video source is 25 FPS. as noted in the guide
i have tried the folowing cd's with NERO Burn v.5.8 (also tried burning at very slow speed)
Hewlett Packard CD-RW
TDK CD-R
Verbatim Datalife CD-R
Your bit rate is way way too low it should be at least 1150kb for vcd
We were all NEWBIES once and the only stupid question is the one that's not asked? -
sorry vcd4me
but it should read .... 1148 kilobits/ sec
thanks for pointing it out.[/b] -
well your not that far off what was the original files bitrate or is that the original files bite rate.
HI it is the original file bite rate. i ended up deleting all the other attemps.
It is probably just a bad file I have had similar problems as well.
I have tried multiple times to re-convert with the same results.
The other problem it could be is your player might not except non-compliant vcds.We were all NEWBIES once and the only stupid question is the one that's not asked? -
While I have given away my 709 now,
The only thing I can think of, is the 709 is VERY fussy about the type of disk that you put in. i.e. the make of disk, I used to use vivastars, allways worked but not in SVCD format.
Does the audio go as well or is it video that pixels? if it is the audio as well it could be a disk problems, the other thing it could be, what version is your bios?
www.709online.com has a lot of stuff about this.
Paul -
Hi paul thanks for your reply i have been trying more tests and checked out the url for my samsung player. The version of my Bios is v.4.51pg (please correct me if it does not sound right) and as for the mpeg breaking when playing on the player out of the attemtps i've made its mainly the video that breaks up and the audio somtimes is ok. I also tried a different music video which is roughly the same,
Faithless -- Insominia
352x288
25,000fps
1150kb/s
44kHz stereo
with this one both the audio and video started to go wrong.
I think the next thing i will try is...
1) try Princo and Vivistars CD-RW (uses say they seem to work better)
2) try the VCD in a different player
3) try differernt mpegs (have done but no joy)
4) ask the audience
Pixelation in certain frames while playing files in a DVD player
By aarelovich in forum Video ConversionReplies: 8Last Post: 4th Feb 2010, 15:47 -
Any reason why most dvd player only support xvid, divx and not rmvb and mkv
By c1steady in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2009, 20:14 -
Media Player Classic no longer playing audio for some reason...
By darkzero297 in forum Software PlayingReplies: 5Last Post: 21st Feb 2009, 15:56 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15 -
Durabrand PDV-709 (Portable DVD Player) Hack Code needed
By Caribsurfer in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Dec 2007, 10:49
