Hello,
I'm curious what's problem is on tape? and if EH65 also has "tbc" why can't fix this ?
(panasonic hs960 is connected to panasonic eh65 dvd recorder)
https://youtu.be/RBtmcY4s1Yc
A quick way to see if the tape is really bad or the EH65 isn't doing it's job is to pull it out of the workflow: do another capture without the EH65 and compare the two captures. If the first is better than the second, the EH65 is working but can't fully correct it, and if both captures are the same, the EH65 isn't doing anything.
There are also some very very rare cases where a TBC, whether internal or external can end up detecting the sync getting things wrong and can end up "miscorrecting" the video and something with less capability/not as wide range of correction works better. It could be something like this going on here, maybe there is some weirdness going on in the non-visible area of the tape that gives the EH65 issues.
I remember digitizing some dubbed/home edited military memory/showoff tape which had spots where the dmr-ES10 and similar went off the charts and ended up making half of the lines in the picture starting in the middle so had to go without proper line tbc for that part. -
Tape deck - head cleaning tape
By hotcheeto in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 1st Sep 2022, 22:00 -
VCT tape video capture: Tape shows annoying VCR Speed and Tracking bar...
By MoonView in forum Capturing and VCRReplies: 7Last Post: 5th Apr 2021, 21:52 -
Help Figuring out Problem with Audio on VHS Tape
By battybarney in forum Capturing and VCRReplies: 22Last Post: 4th Nov 2020, 18:29 -
vhs tape question, 1/2 tape is fine and 1/2 way thru gets lines
By tomthetank in forum Newbie / General discussionsReplies: 8Last Post: 13th Jan 2019, 07:14 -
VHS tape problem
By Nige58 in forum MediaReplies: 8Last Post: 13th Sep 2018, 14:51
