I would like to export archival video to FFV1 format, but cannot find the option anywhere within Adobe PP. Do I have to install the codec separately or perhaps some plug-in for it? Thank you.
Perfect, thank you!
Do you know how I can test if an FFV1 encoded file is truly lossless? I tried to export an uncompressed AVI to FFV1, then export that back to an uncompressed AVI with the same settings as before, but the two files ended up being different sizes by a few sizes, so I couldn't compare them. -
You can use various metrics, such as PSNR to test whether a video is lossless
Sometimes there are other conversions behind the scenes that might make something not lossless - e.g. colorspace/pixel format conversions . You'd have to provide more details
e.g. there might be decoding issues - not all "lossless" codecs are handled as lossless in NLE's.
Uncompressed AVI, in the same pixel format, should always be the same filesize. There might be a few bytes from metadata differences, but the PSNR will always be infinity between 2 identical sources
Adobe Premiere Pro 2022 Video in Timeline?
By vega69-ux in forum EditingReplies: 0Last Post: 24th Feb 2022, 19:30 -
Black margin when exporting won't go away - adobe premiere
By sarit1 in forum Newbie / General discussionsReplies: 2Last Post: 5th Jan 2022, 15:38 -
Not able to render timeline in adobe premiere pro
By Robbson321 in forum EditingReplies: 0Last Post: 10th Apr 2021, 01:48 -
Is Final Cut Pro really that much better than Adobe Premiere Pro?
By videoguy102 in forum EditingReplies: 5Last Post: 9th Oct 2020, 06:34 -
Exporting MPEG2 Video Degradation Blurry Jittery Adobe Premiere
By ESP1138 in forum Video ConversionReplies: 5Last Post: 17th Jan 2020, 09:57
