Last night, I try to capture .avi from VHS via VDub1.4.9 and the capture went well (3.6G file) except that when trying to re-encode in mpg (via Panasonic2.51 & also tmpgenc and LSX), the encoding stops at the middle saying that an error occured......
I encoded same files few months ago and had no probs at all....... I think I used Vdub 1.4.7 but same Matrox settings etc....
My question is, as it seems to be related to the "famous" 2G and 4G limits, how all of this occured as I have the same pc settings (fat32, etc..) ???
Capturing is ok.......
but right at 2G, an capturing error seems to happens......
How?? why?? and what to do to avoid it like previously??
Merci!!!
"OO"
P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo
another detail:
The file seems to be perfect(3,6G/56min) but when playing it, it stops right at 2G, around 36minutes if you prefer....then , no image and no sound....
Any one has a hint about this bug??
"OO"P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo
Bizarre vertical lines
By Asterra in forum Capturing and VCRReplies: 55Last Post: 17th Apr 2011, 22:46 -
Bizarre sync issue
By cinesimon in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2011, 17:44 -
Bizarre Happenings
By Mitchum22 in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2008, 10:36 -
Aspect ration problems when encoding in VDub
By sd_smoker in forum Newbie / General discussionsReplies: 12Last Post: 5th Jul 2008, 12:24 -
Brightness fluctuation problems - capt from VHS thru ADVC110
By ChrisMtl in forum Capturing and VCRReplies: 18Last Post: 7th Dec 2007, 14:47
