Results 1 to 9 of 9
  1. Hello, just wondering does anybody know if it is possible to download better quality than the MPD is limited to? As you can see in the following MPD it only allows up to 540p in the internet browser on PC, but can happily cast in full HD from the app to my tv.
    https://origin.vod.videoland.bedrock.tech/videoland/output/1/4/f/14f9f6aa0a2dfac1df1374e0be09de76e2de3d77/static/38962_35ceb096844bfc3599de63590fb49d00_web_dash_upTo540p_540p_drm_software.mpd
    Any advice or help would be appreciated
  2. Did you try changing to a different browser ... say Edge?
  3. Originally Posted by jack_666 View Post
    He did
    [Attachment 67276 - Click to enlarge]
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  4. Originally Posted by jack_666 View Post
    Cheers for the reply but unfortunately tried that an and get the same as chrome, also tried Firefox with the same outcome.
    Dec 2021
    Spain
    from your own testing i think you can see you need to get the mpd from something else...
    Maybe Edge..??
    because thats what gives 1080p that you tested right?
    or maybe i misred
  6. HTML Code:
    https://origin.vod.salto.fr/m6/output/2/9/5/295d703767a69887288c370d49ee2751fe580fb114bd52e1141e17e7c1703c1f/static/c177732_web_drm_540p_dash_v1.mpd
    https://origin.vod.salto.fr/m6/output/2/9/5/295d703767a69887288c370d49ee2751fe580fb114bd52e1141e17e7c1703c1f/295d703767a69887288c370d49ee2751fe580fb114bd52e1141e17e7c1703c1f_web_drm_hd_dash_v1.ism/Manifest.mpd
    https://origin.vod.salto.fr/m6/output/2/9/5/295d703767a69887288c370d49ee2751fe580fb114bd52e1141e17e7c1703c1f/295d703767a69887288c370d49ee2751fe580fb114bd52e1141e17e7c1703c1f_web_drm_hd_hls_v1.ism/Manifest.m3u8
  7. Originally Posted by kenyard View Post
    Maybe Edge..??
    or maybe i misred
    You are correct that I need to get the mpd from another device but that's the part I'm struggling with. Edge I've tested it and it has the same output as chrome. Its the app where I was able to cast in full HD.
    Question:
    How did you ascertain the app contained a full HD mpd? Is it possible that the app had the same lower resolution mpd and the device, to which you casted, did an up conversion?
  9. Originally Posted by jack_666 View Post
    Question:
    To be honest I was just guessing that the app contained the full HD MPD. I assumed that my TV wouldn't be capable of upscaling that well. You are probably correct with the TV doing a conversion. Sorry pretty new to this world.
