I am trying to digitize the family vhs colection and I was following the great guide over at https://www.reddit.com/r/DataHoarder/comments/is6hml/the_ultimate_vhs_capture_guide/?u...eb2x&context=3 but I have run into a problem. During the capture the video will jump back and forth by several frames continuously. My setup currently is JVC HR-9500U → svideo →dazzle dvd recorder → virtualdub. I tested all the parts and they all work correctly. The vhs player plays the tap back correctly on tv, capture card can display the vhs play fine (though i dont have many composite or svideo things to test it with). Its just when I capture. Is this a tbc problem? The JVC HR-9500U I have has a time corrector in it and I made sure it was on but still have the problem. Do I have to get another tbc? Attached in this post is a test tape i am using to get all the kinks out before i get the family tapes (yes there is no audio, that is on purpose).
Results 1 to 1 of 1
Weird Question - How To Remove Cat Urine From VHS Tapes?
By ThePolaroidMan in forum RestorationReplies: 8Last Post: 29th Jun 2022, 08:44 -
Problem capturing audio with some Hi-Fi vhs tapes
By Altruo in forum AudioReplies: 5Last Post: 23rd Apr 2021, 20:05 -
Flickering colors when capturing some VHS-C Tapes
By boriswinner in forum Capturing and VCRReplies: 11Last Post: 24th Mar 2021, 09:21 -
Vertical rainbow effect when capturing some vhs tapes.
By C3PU in forum Capturing and VCRReplies: 1Last Post: 28th Jul 2020, 11:52 -
Capturing VHS tapes
By mtamimi in forum Capturing and VCRReplies: 7Last Post: 3rd Mar 2018, 01:09
