Hello,
i have a video file with 30 fps and i would like to convert it to a standard BD. Tested DVDfab TSmuxer and multAVCHD so far, always with the same results. The BD has minor but noticable stuttering. :/ I'm sure it's because of the 30fps oddity, but the video is unique. So i have to work with this given file. :/
Is there any chance getting a smooth playing BD out of this?
Thanks in advance and sorry for the (maybe) bad english
Here is a Mediainfo log:
Format : Matroska
Format version : Version 4 / Version 2
File size : 9.05 GiB
Duration : 2 h 42 min
Overall bit rate : 7 955 kb/s
Encoded date : UTC 2022-10-10 12:48:31
Writing application : mkvmerge v6.5.0 ('Isn't she lovely') built on Oct 20 2013 12:50:05
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Video
Format : AVC
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 7 808 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.126
Stream size : 8.65 GiB (96%)
Writing library : x264 core 152 r2854 e9a5903
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=60 / keyint_min=31 / scenecut=0 / intra_refresh=0 / rc_lookahead=30 / rc=2pass / mbtree=1 / bitrate=7808 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=7808 / vbv_bufsize=15616 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode : Dolby Digital
Format settings, Endianness : Big
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 224 MiB (2%)
Language : German
Service kind : Complete Main
Default : Yes
Forced : No
Many non compliant issues:
Some BD players might play out of spec BD's - but strictly speaking it's not compliant because of 30/1 FPS, keyint 60 (2 sec GOP is allowed if buffer is <15000, but you 15616 buffer), it's "labelled" as L4.2 (L4.1 is max for BD), no --blu-ray- compat switch, and 30000/1001 progressive encoding is "illegal", it needs to be encoded as mbaff or using --fake-interlaced switch. Any or all of these can cause stuttering on a BD player
So it would need to be re-encoded with compliant settings, and retimed to 30000/1001 FPS (both audio & video)
25 fps - eu bluray
By max_cady in forum Newbie / General discussionsReplies: 7Last Post: 14th Jul 2022, 02:45 -
Does increasing fps 30-->60 when (ffmpeg) re-econding repair stuttering?
By pxstein in forum Newbie / General discussionsReplies: 1Last Post: 24th Aug 2021, 09:41 -
Problem with HSBS 3D mkv when converting from in-mux 3D bluray
By NetDragon in forum Video ConversionReplies: 0Last Post: 25th Jul 2021, 17:43 -
Stuttering with MKV file (SVT-HEVC) on blu ray player Panasonic
By marco000 in forum Video ConversionReplies: 11Last Post: 10th Jul 2021, 09:03 -
QTGMC mov 29.970 (Constant fps) Ends up 58.42 FPS rather than 59.940
By VidNew23 in forum Video ConversionReplies: 9Last Post: 8th Apr 2021, 00:21
