Hello everyone
I have an old VHS tape from high school that I recently had digitized, to learn that it had what I now understand to be tracking errors pretty bad through much of it. I've tried to do a little research on my own to determine if anything could be done to fix it, and it seems like in some cases it's possible, but I thought it would probably be a good idea to just show a clip of it to people who are smart about this topic before I try to pay someone for a fruitless restoration attempt. I've attached the clip.
If it looks like it could be fixed or moderately improved, does anyone have recommendations on companies that can do this? There are a few local businesses in my area that digitize tapes, but none of them make any mention of restoration. I'm guessing I'll probably have to ship it somewhere, if in fact there's hope for it.
Thanks in advance to all for any help or advice!
Results 1 to 9 of 9
Can't be fixed through software.
My verdict would be that a new capture (digitalization) is needed.
My guess is that the tape and the used vcr might need cleaning and realignment, but I haven't handled vhs tapes for 20+ years.
Others probably can tell you whether this can be fixed or not.
Cu Selur
Ps.: Attached an example of what https://pastebin.com/nW4xrSuy would get you with the above file.Last edited by Selur; 15th Oct 2022 at 03:57.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Thank you Selur, some search results suggested that this could be fixed with a Time Based Corrector, I suppose that must be used during the capture. I'm wondering if that might work in this case if I send the tape to a place that has one, or if it's too bad for that.
The tape itself looks to be in good condition to me. It's in all likelihood the VCR. In my limited experience, a TBC probably wouldn't fix this, because the picture itself looks good and steady. Have you tried adjusting the tracking as it is playing? All VCRs have a tracking adjustment system using the remote. For example, one of my VCRs uses the Program buttons to adjust tracking when playing a tape. When adjusting the tracking, if nothing changes, it could be baked into the tape when it was recorded, but probably not.
There is so much noise at the top, and it is so persistent, that there is no way to repair it using software.
A better VCR is always going to provide a better result, but a better operator is even more important. Whoever transferred this tape obviously did not pay much attention during the transfer. Some tapes do not track well. All VCRs have manual tracking adjustment and you can sometimes "tune in" the playback to reduce or eliminate much of the noise. You can at least get it so that you only have a little at the top and/or bottom. You can then crop that out.
The good part of the picture is definitely jumping up and down. A TBC might help, although I suspect most of the jumping is just another artifact from the bad tracking. Some VCRs have a correction circuit for EP tapes and if you enable it, you can sometimes reduce the jumping. However, you have to get the tracking fixed because all the other issues are minor by comparison. -
Why is it a 15fps video? It is showing only 1/4 of the samples - is that what they gave you ?
Nah that part is my fault. They gave it to me on a DVD, I'm afraid I don't have much experience in ripping video either. I went for a small file size
I haven't tried myself, as I had a local place transfer it. I do have an old VCR but no remote for it any longer, and I'm not sure I trust it. Your statement gives me hope though that it's likely not the tape
Yeah it doesn't have to be perfect by any means, I just want to get all that noise off of everyone's face, haha.
Based on what both of you have said, it sounds like I just need to find the right place that will know how to make the proper adjustments and there's a good chance it can be done. Which is what I was hoping for, so thank you! -
Try manually adjusting the tracking to clear up the top part of the frame. If you can't get the entire frame to clear up, capture twice once with the top clean, once with the bottom clean. Then join the two good parts together in an editor.
VCT tape video capture: Tape shows annoying VCR Speed and Tracking bar...
By MoonView in forum Capturing and VCRReplies: 7Last Post: 5th Apr 2021, 22:52 -
VHS Tape Issue - Fuzz/Static/Tracking That Cuts Out And Comes And Goes
By Joseph Beasley in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2020, 05:15 -
VHS Tape won't play back - just says "tracking"
By itm2 in forum RestorationReplies: 16Last Post: 22nd Aug 2020, 19:24 -
Removing tracking lines?
By DiggyDre in forum RestorationReplies: 7Last Post: 15th Feb 2019, 20:56 -
vhs tape question, 1/2 tape is fine and 1/2 way thru gets lines
By tomthetank in forum Newbie / General discussionsReplies: 8Last Post: 13th Jan 2019, 08:14
