Hello, I have a .mp4 on a folder. I need to turn it to .m3u8 in multiple resolutions and streaming it online.
To do so, I used mmpeg. This command that I found online:
and it generated me the .m3u8 file correctly and all the various .ts chunks of videos in the relative resolution folders.Code:ffmpeg -y -i file.mp4 -preset slow -g 48 -sc_threshold 0 -map 0:0 -map 0:1 -map 0:0 -map 0:1 -map 0:0 -map 0:1 -map 0:0 -map 0:1 -map 0:0 -map 0:1 -map 0:0 -map 0:1 -s:v:0 1920*1080 -b:v:0 1800k -s:v:1 1280*720 -b:v:1 1200k -s:v:2 858*480 -b:v:2 750k -s:v:3 630*360 -b:v:3 550k -s:v:4 426*240 -b:v:4 400k -s:v:5 256*144 -b:v:5 200k -c:a copy -var_stream_map "v:0,a:0,name:1080p v:1,a:1,name:720p v:2,a:2,name:480p v:3,a:3,name:360p v:4,a:4,name:240p v:5,a:5,name:144p" -master_pl_name master.m3u8 -f hls -hls_time 10 -hls_playlist_type vod -hls_list_size 0 -hls_segment_filename "v%v/segment%d.ts" v%v/index.m3u8
I uploaded everywthing in the webserver but when I try to stream from the .m3u8 it simply doesn't start. I get generic errors. I tried multiple players, none worked. If I download the files in my computer though, I can stream them fine.
My doubts are mainly 2:
- is there any mistakes in the command I found online or is it fine? Does it has the right headers for online streaming?
- is it possible that some error happened during encoding? specifically, multiple times I get lines like this in the command line during the encoding
that writing=N/A and bitrate=N/A does it means that chunk it was skipped or something?HTML Code:Opening 'v1080p/segment96.ts' for writing=N/A time=00:16:13.82 bitrate=N/A speed=0.566x
Remove all the "-b:v:0 1800k", "-b:v:1 1200k", etc. Then add "-crf 26" to the list of x264 arguments, eg, change "-preset slow -g 48 -sc_threshold 0" to "-preset slow -g 48 -sc_threshold 0 -crf 26". In practice this may not work well without VBV settings for each resolution.
tango stream m3u8 ffmpeg download doesn't work
By swimgoggles in forum Video Streaming DownloadingReplies: 2Last Post: 6th Jun 2021, 13:34 -
Help ! master.m3u8 pointing to wrong video !
By Zehpul1 in forum Video Streaming DownloadingReplies: 2Last Post: 19th Jun 2018, 17:31 -
my .m3u8 video stream does not work in google chrome
By neuronetv in forum Video Streaming DownloadingReplies: 2Last Post: 26th May 2018, 03:13 -
VLC doesn't play m3u8 file
By Nagasaki in forum Video Streaming DownloadingReplies: 0Last Post: 4th Mar 2018, 12:48 -
By pittbox in forum Video Streaming DownloadingReplies: 3Last Post: 15th Oct 2017, 19:34
