[Attachment 67193 - Click to enlarge]
one of the problems I have come across is if you have a microphone close to the top carrying handle, the slightest hand movement on the handle is picked ujp by the microphone, So the answer is to isolate the handle from the hand. I thought about it then realised I still have rolls of tape used for greenhouse to insulate between glass and metal greenhouse frame I never used. Sticky on one side smooth on the other and easily removed if so wished. In this photo above I have shown it on one side of fhe handle but since then I have also done other side underneath and on top. it works extremly well and also provides a better grip on handle as a bonus
something like this link which is what i used. you may get other sizes on different web site
[URL unfurl="true"]https://www.greenhousepeople.co.uk/products/898/adhesive-foam-strip-for-glazing-15m/?gclid=CjwKCAjwqJSaBhBUEiwAg5W9p1Lepo73Z5VzaQtWlyH Va13fCQVtGSzQH54I6Luq1s4mNVymqFaoBBoCvB8QAvD_BwE[/URL]
Results 1 to 1 of 1
Tip - How to Capture with AJA Kona LHe Plus
By jwillis84 in forum Capturing and VCRReplies: 2Last Post: 19th Jan 2023, 09:08 -
Sony Camcorder TRV815 Hi8 old tapes won't playback in camcorder
By Dforsythe in forum Newbie / General discussionsReplies: 11Last Post: 9th Dec 2019, 16:21 -
Simple usb flash drive fix tip
By johns0 in forum ComputerReplies: 4Last Post: 10th Jun 2018, 05:58 -
I can't handle this DVD, please can you help me?
By TeNSoR in forum Newbie / General discussionsReplies: 11Last Post: 3rd Jan 2018, 20:21 -
I need help on how to handle this video please
By pooksahib in forum Video ConversionReplies: 10Last Post: 1st Jan 2018, 15:39
