Hi, I have two sources of the same video: the first 8-bit depth, bitrate at 33.7 Mb/s, H264 and occupies 12.3 GiB; the second 10-bit depth, bit rate 4055 kbps, H265 and occupies 1,737 GiB. Which one would you choose? I have no problems with space I care about the quality.
The first 8-bit depth, bitrate at 33.7 Mb/s, H264 for me. (I suppose the resolution is the same as the h265 video)
The 33Mb/s h.264 video is likely to be better than the 4 Mb/s h.265 video. But there are too many unknowns to say for sure. Beyond what ProWo points out about the resoulution... What encoders were used? Different encoders within the same family do not all deliver the same quality. What settings were used? An encoding at fast settings delivers lower quality than the same encoder at slow settings. What is the nature of the video? Some videos require more bitrate than others. Did both start with the same source? What if the h.264 video is upscaled from a crappy VHS tape and the h.265 video is from a high quality Blu-ray disc? Personal taste enters into the decision too. People are sensitive to different types of flaws. Some people like the noise reduction (loss of grain) that comes with low bitates.
In the end, the only way to know for sure is to download both videos and compare them for yourself. -
Since the 12 GiB video is probably the better version you should download it. Another 1.7 GiB for the other video is only 15 percent more for a verification.
Can I force a higher video bitrate for netflix?
By tripnikk in forum Video Streaming DownloadingReplies: 9Last Post: 3rd Dec 2021, 17:56 -
Can you increase bitrate higher than the original raw source video ?
By GoodEnough in forum Newbie / General discussionsReplies: 16Last Post: 1st Jan 2021, 07:38 -
10-bit to 8-bit Video File Conversions - the easy (free) way!
By VideoWiz in forum Video ConversionReplies: 10Last Post: 6th Feb 2020, 03:24 -
Re-encoding audio and video to lower bitrate and change channel to mono
By DennisO in forum AudioReplies: 7Last Post: 26th Dec 2018, 14:25 -
Is there an Avisynth Lossless Video Codec that uses lower bitrate for 720p?
By VideoFanatic in forum Video ConversionReplies: 7Last Post: 17th Apr 2018, 19:44
