Hello! I’m new to this forum, and I did my best to find a thread answering my question but failed. Apologies if it’s basic knowledge!
I was wondering if there is a way to make shortcuts in Subtitle Edit for different colors than the four ones already in the settings. Is there a way to at least save some html color codes that you use most frequently, so that you don’t have to handpick them from the color pop up window every time?
Thank you in advance!
In latest version of Subtitle Edit the color picker saves the last eight colors... a little better.
You can also setup shortcuts for your favorite eight colors if you edit Settings.xml - see e.g. "<Color1>" - and Options - Settings - Shortcuts.
Is there a way to edit my skin-color and eye color on video?
By joewinko in forum EditingReplies: 6Last Post: 2nd Dec 2020, 14:48 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52 -
This dummy can't sync subs with Subtitle Edit or Subtitle Workshop :-(
By inspector_plodder in forum SubtitleReplies: 6Last Post: 24th Aug 2018, 18:33 -
Pixelated and laggy video on Subtitle Workshop and Subtitle Edit
By Valerc in forum SubtitleReplies: 5Last Post: 15th Jul 2018, 11:37 -
By Valerc in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2018, 14:15
