For the longest time when using RGB devices (such as my CFW PS3) I could not adjust the settings.
That has now changed thankfully with a firmware update, but sadly 480p, (for playing PS2 games on my CFW PS3)
had some pixels cut horizontally on both sides and has been replaced with a more stretched resolution to cover what was cropped.
Why would they do this? It makes no sense whatsoever. It isn't much that was cropped, but I now some of the text on the side cannot
be seen.
For example: Since my PS3 has CFW, I can play a good amount of PS2 games via the built-in emulator, and it has a mod that allows you
to monitor the PS3's temp while running but now part of that is cropped out thanks to their incompetence.
Edit: This seems to be an issue when PS2 games on PS3 internally switch to 480p, as in 720x480p widescreen. The screen is fine when the game is in 640x480i internally.
Results 1 to 1 of 1
Can't get Vizio TV to play audio thru bose portable speaker
By peggypwr1 in forum AudioReplies: 2Last Post: 30th Jun 2021, 21:40 -
How to correctly remove horizontally shifted frames?
By bruno321 in forum RestorationReplies: 0Last Post: 23rd Feb 2021, 02:31 -
Horizontally flipped video from phones ... WHY ?
By d4005 in forum Newbie / General discussionsReplies: 10Last Post: 29th Apr 2020, 01:35 -
Vizio Soundbar not working with 8-yr-old Samsung TV
By johnharlin in forum AudioReplies: 7Last Post: 28th Dec 2019, 20:27 -
Can I add audio Bluetooth to Vizio TV?
By peggypwr1 in forum AudioReplies: 4Last Post: 19th Nov 2018, 01:01
