Hello,
i've decided share this because in all site see that people have same problem
i have easy cap chinese, cheap, of secondhand
and for rca for vhs image shake or jump or move up to down, can't use for capture
but now after all
i have the "solution", is very simple
the solution is just use a cable rca to s-video, and conect vhs through "s-video"
now with this working perfect, image totally stable perfect!
you can buy any cheap, simple cable with rca_male <-> s-video_male
or if you don't have this cable you can build this using capacitor of 670fp, search tutorials
just try and tell me, regards
Closed Thread
Results 1 to 11 of 11
It is the weekend and most of the regulars are not here....
But.....
I needed to check my calendar to satisfy me that it was not April 1 when you posted this.
In a word or three, there is nonsense and greater nonsense. I am struggling to decide which category your 'solution' should go in to.
But by all means clarify your solution with before and after captures from the same tape and sequence. Or merely read the difference between composite (RCA) and s-video and convince me (and others who have been doing this for more years than you will admit to) that you 'solution' actually has merit.
That's a really stupid "solution", aka not a solution at all.
Easycap earned the nickname Easycrap.
What you suggest here is that s-video doesn't work, only the composite.
Even if true, the issue with Easycap is also with values. Your contrast, brightness, colors, etc -- all screwed up.Want my help? Ask here! (not via PM!)
I'm not sure how this would help unless you happened to use a composite->s-video converter of some sort that is an active converter that regenerates sync info and what not.
Oh, Good to know the translation for HIV as well. I like that he put a price on it, Very meticulous.
It was an opportunity to put my Spanish classes (taken long ago and largely forgotten) to good use. Portuguese has similar grammar and many similar words. Oops, somehow I misremembered the OP's location when using Google Translate. Argentina is a Spanish-speaking country, so it's "virus de inmunodeficiencia humana"
Those simple bi-directional converters merely separate luma and chroma from a composite video source and combine luma and chroma from an S-video source. I don't see how one of those could correct jumpy video output from a VCR, which is reportedly caused by a mechanical problem.Last edited by usually_quiet; 9th Oct 2022 at 17:48.
It is possible that the capacitor in that adapter boosts the signal a little bit which boosts the timing signal as well so the crappy capture device can lock better since it expects a clean and high level signal from sources such as DVD players, game consoles and similar digital devices with analog output. Keep in mind most of those signal conditioners sold back in the 80's and 90's to supposedly clean the video signal didn't have any time base correction in them or any sort of chips just good old filter capacitors and resistors.
Digital Video to VHS or HDV (miniDV) best solution!
By zhigar in forum Capturing and VCRReplies: 3Last Post: 25th Jun 2021, 00:31 -
If you shake your VHS player while recording will it affect the recording?
By bigbadben in forum Newbie / General discussionsReplies: 6Last Post: 18th Oct 2020, 08:17 -
EasyCap strange issue while recording VHS
By jackichan2004 in forum Capturing and VCRReplies: 11Last Post: 13th May 2020, 14:33 -
Easycap DC60 VHS video/audio out of sync
By boriswinner in forum Capturing and VCRReplies: 4Last Post: 18th Nov 2018, 07:21 -
vhs/easycap - jumping image
By incanto in forum Capturing and VCRReplies: 24Last Post: 31st Oct 2017, 08:21
