Hi, I have problems of merging audio stream into the avc1 encoded mp4 (The mp4 contains Video only, converted from ts by ffmpeg automatically, the process is done by a browser script, the original ts files are encrypted ), I tried many tools to merge the VideoOnly.mp4 and AudioOnly.mp4, but all failed at the first step, I can't import the mp4(video only) as it's avc1 encoded, so I can't go any further, then I tried to extract the video stream from the mp4 with Yamb, and failed again, it says "Access violation at address 0045AA7C in module Yamb.exe . Read of address 00000004", now I'm confused and don't know what to do, please I would be really appreciate if anyone could help with this issue, thanks in advance!
Try mkvtoolnix.
Start the app, drag and drop both mp4's in the upper field, click start multiplex.
This muxes the 2 streams to a new mkv file.
If you need mp4, then try My mp4box gui. -
see this youtube video - https://www.youtube.com/watch?v=GdfE9WiIQqo
Difference between FourCC codes "avc1" and "avc3"? avc1 with sound prob?
By pxstein in forum Video ConversionReplies: 1Last Post: 31st Jan 2022, 04:14 -
Cannot merge 2 videos after encoding one
By Budman1 in forum Video ConversionReplies: 3Last Post: 14th Nov 2020, 03:06 -
AAC not encoding at specified CBR bitrate
By killerteengohan in forum AudioReplies: 3Last Post: 24th Jul 2020, 07:49 -
Encoding to NERO AAC problem
By yaston in forum AudioReplies: 1Last Post: 1st May 2020, 20:40 -
7.1 AAC encoding
By davidcameron in forum AudioReplies: 2Last Post: 12th Apr 2020, 18:06
