Can anyone please help me to decrypt the aes 128 key
Here is the link
https://www.durgasoftonline.com/s/preview/courses/Core-Java
You can get m3u8 file from there and key is in k/timestamp
Thanks in advanced!!!
Results 1 to 21 of 21
g = function(a) {
function b(a) {
if (!(this instanceof b))
throw new TypeError("Cannot call a class as a function");
a = w(this, (b.__proto__ || Object.getPrototypeOf(b)).call(this, a));
var k = a.load.bind(a);
a.load = function(a, b, e) {
var c = "ey endsWith url amp onSuccess data subarray ECB mode NoPadding pad decrypt AES stringify u8array enc buffer".split(" ");
if (a[c[2]][c[1]](c[0]) || a[c[2]][c[1]](c[3])) {
var d = e[c[4]];
e[c[4]] = function(a, b, k) {
var e = new Uint8Array(a[c[5]])
, m = e[c[6]](0, 16)
, g = e[c[6]](32, 48);
e = cjs[c[12]][c[11]](convertArrayToBase64(m), cjs.enc.Base64.parse(spka), {
mode: cjs[c[8]][c[7]],
padding: cjs[c[10]][c[9]]
e = cjs[c[15]][c[14]][c[13]](cjs[c[12]][c[11]](convertArrayToBase64(g), e, {
a[c[5]] = e[c[16]];
d(a, b, k)
k(a, b, e)
return a
v(b, a);
return b
this is a decrypter function , can anyone help write a streamlink python plugin to override decryptor function -
code47 wrote
Please give an example of how this script works, like for example some input and the decrypted output 32 character key.this is a decrypter function , can anyone help write a streamlink python plugin to override decryptor function
If this script works, then the process can be incorporated into another script that takes this output and pass it to streamlink.
Therefore, please give a demonstration of this script in action. Thanks -
This script is taking the input from timestamp url and output is decrypt key
I am not good in python but someone good in python can create a script to override this function
Which can be used with streamlink as a plugin.py -
Did anyone tried the curl command , the curl command is giving the keys but the problem is keys are changing for every request
Is there a curl command to download video and decrypt the video in one request -
Statement is both factually true and false.
It is true due to the fact that timestamp changes with each call. It is false in that the curl output is not the key. The curl output is used by the aes.js to create the key. The key does not change. Consider the curl output as a pointer to the key.
The decode algorithm takes various timestamp data as the input and produces the one unique output.
Probably the timestamp output has the current time embedded. Hence there can be an infinite number of timestamp outputs.
Your best bet is to study the code that you posted. Get your code working and capture the output. Once you get the correct output, then it becomes a trivial task to incorporate into a script. -
Hey jack_666
I am not a very good developer but I am trying my best to find the function which is taking input from timestamp response
Can you pls lend a helping hand in finding that function -
m3u8 url:
https://d2s2mc5mfsrgxi.cloudfront.net/spees/w/o/5e356a710cf24531c92ac49f/v/5e6e6c1f0cf...fbe/index.m3u8
key:
base64: 0WEq1p83crz9Jn2aSN0zgg==
hex: d1612ad69f3772bcfd267d9a48dd3382 -
Please help. I have one video hosted on CloudFront. Which I cannot download.
https://d2qny97nu4rj64.cloudfront.net/spees/w/o/61a72b8a0cf2e2301bff3bc0/v/62a3c66e0cf...f65/index.m3u8
It has AES 128 encryption. Can anyone help me with this? -
Bro I wanna know how did you all get the keys, and on whih function does key depend on, can anyone clearly state.
AES 128 Key, How do i decrypt or find the key?
By GirlsGill in forum Video Streaming DownloadingReplies: 12Last Post: 12th Feb 2024, 09:03 -
Decrypt AES 128 key m3u8
By icebreaker101010 in forum Video Streaming DownloadingReplies: 4Last Post: 6th Oct 2022, 12:26 -
m3u8 to mp4 (AES-128 Encrypted)
By vel3ro in forum Video Streaming DownloadingReplies: 4Last Post: 19th Jul 2021, 19:11 -
How to decrypt AES-128 encrypted m3u8 TS files?
By canete in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Jan 2020, 14:42 -
Decrypt .ts files (AES-128)
By Broken1334 in forum Video Streaming DownloadingReplies: 1Last Post: 21st Jun 2019, 06:25
