Page 7 of 8
FirstFirst ... 5 6 7 8 LastLast
Results 181 to 210 of 224
    Feb 2022
    Search the forum first!
    Originally Posted by arakelov2 View Post
    Ok, maybe I didn't explain myself well. I'll try again:
    So I changed the CDM: renamed the device.wvd to something different and copied another .wvd from inside a zip named REAL-CDM-L3-main.zip, dowloaded from some thread I don't remember now...
    Run it again and... TADAAAAA!!!
    Best regards.
    Two effing hours of my life gone because a CDM is blown?
    I've known since it returned from testing that the code worked on the site in question, so if it didn't work you for it must have been down to you.
    However, a rejected CDM was off my radar.
    If you read the development history of hell3.py you'll see the GUI came last, and all recommendations are now to use the GUI. Why wouldn't you? And indeed the plan is to drop the Terminal version soon. I introduced pyperclip myself here to VH in a number of earlier programs. I ceased to use because I found it could introduce artefacts into the text and its use confused non-technical users. If you find it helps, all well and good. Allow me to quote myself:-
    For you and all AllHell3 users: If you go to a tool-shop and buy a chisel you'll find it sharp. And for some it will be good enough. But if you want it even sharper, polish the chisel back to a mirror finish, and then put an edge on the tool. You'll make it your own.
    The script you have is tool and it can be tuned to your need.
    To be clear, everyone despite assertions, Allhell3Gui works fine on this site in question - if you feed it a REAL i.e. non-virtual CDM - one extracted from a proper Android device - that it.
    Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
    Feb 2022
    Feb 2022
    Feb 2022
    Feb 2022
    Feb 2022
    Feb 2022
    Feb 2022
    Feb 2022
    Feb 2022
    Feb 2022
  23. Member SE14man's Avatar
    Jul 2005
    Queensland
    Probably best to avoid engaging with Angela. Her head has disappeared way too far up her own arse. You can't reason with someone like that.
  24. Member
    Feb 2022
  26. Member
    Feb 2022
  28. Member
    Feb 2022
  30. Member
    Feb 2022
