I recently got a brand new computer with a WinTV capture card. Been capturing files ever since and converting them to SVCD. Since i like to keep the stuff i capture, i'm always aiming for picture quality, which means large mpeg files.
Now here's the question...
Been searching with a magnifying glass for a program that can split my mpeg files according to a specific filesize. I don't care if a program can split a file after 35 minutes. I wan't to split it after 700 Mb or whatever i can fit onto my CD-R. Please tell me such a program exists and where i can find it.
Think you can do it with vcd cutter
open film and devide clip by 2 (or how many you want) you get clips of more or less equal size -
bbmpeg, get it in the tools section.
If your making a svcd tell it to cut at about 790MB's for an 80 min cdr and 730 for a regular cdr. This will totally fill the cdr. -
Thanks. Actually i had tried bbmpeg before but couldn't get it to work (must have been some malfunction between the keyboard and the operators chair :) ). It all work just like i wanted it now.
How to split a .TS video file based on time (not file size!) ?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Sep 2020, 18:32 -
DVD split with DVDFab. Movies don't run smoothly, goes back to first scene
By whenloverageswild in forum DVD RippingReplies: 1Last Post: 15th Jul 2009, 13:16 -
How to split video to different size each
By sirganisch in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2008, 13:40 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35 -
dvd movies don't screen on monitor properly are split into 3 sections
By beachychick in forum Software PlayingReplies: 3Last Post: 29th Oct 2007, 19:03
