I recently bought a bluray player, an LG because back in the day last time I bought one, LG played just about any file from a USB thumb drive.
So I bought one and finally got around to using it and I inserted a thumb drive and the LG does not recognize it.
It's formatted FAT 32, my computer recognizes it, my LG TV recognizes it but my new LG bluray does not!
It's a simple 64gig thumb drive that I've used several times and had no problems with. Major brand, and as I said it works fine with the LG tv.
Any idea why?
DO LG blurays no longer play files like MKV? Even though the LG TV does?
So what NEW bluray nowadays plays the most files - especially MKVs?
Thanks.
Please forgive me for not looking for this answer. I am in the middle of moving into an old house, doing repairs, on top of working and doing 10 other things, so if someone could just answer this simple (?) question I'd appreciate it!
Thanks.
Results 1 to 9 of 9
This.
MKV and AVI are containers that can contain multiple different types of video and audio. https://en.wikipedia.org/wiki/Comparison_of_video_container_formats
If you're on a PC, run Mediainfo and post what's inside your files.
Blu-Ray players are very particular about what type of files they'll play, partly because of the Blu-Ray Association license. You TV on the other had has a built in media player, not bound by that license.
I you want something that plays most video types, both container and codecs, get a standalone media player like an Android Box. Lots of discussion and recommendations here: https://forum.videohelp.com/threads/386414-Android-Box -
Brand means nothing when it comes to new models and different lines from the manufacturer. Specs can differ according to what's available at the time and price range of the product. -
Before you do anything else, read the Blu-Ray player's instruction manual (or at least post the player's specific model number here so that others might be able to see what restrictions you might be working with). As mentioned, BD/DVD set-top players do tend to be extremely picky about what they can and can't play from an external drive. I've even had instances in the past where a player refused to recognize a flash drive because it didn't detect anything it considered 'playable' on it (and that's not getting into the players that want to see the content in specific folders/directories...).
Heck, for all I know, this could be a model LG decided to NOT to have the ability to play anything from an external USB drive.If cameras add ten pounds, why would people want to eat them? -
It could be that your 64GB thumbdrive is too large and isn't reconized.
Try with a thumbdrive of 32GB or less if that works. -
BINGO! I tried a 16gig instead of a 32 (or 64?) gig and it worked.
Sorry I did not respond to earlier responses. I was going to finally give the name and model number of the unit ... then I tried the 16gig drive and it worked.
Just been too busy to get over here to the computer and my phone didn't have this password...
Anyway thanks for the help!
Joining several AVI files with progressive audio delay + converting to MKV
By motorola8800 in forum Video ConversionReplies: 3Last Post: 24th Aug 2021, 20:57 -
AmarecTV no longer sees my USB-Live2
By Rahneshin in forum Capturing and VCRReplies: 31Last Post: 27th May 2021, 12:18 -
PotPlay no longer plays HEVC videos
By Yanta in forum Software PlayingReplies: 16Last Post: 21st Jul 2020, 09:02 -
Impossible 2 mux mp43 and AC-3 files into AVI container; DVD-from-USB issue
By Pompilius in forum Video ConversionReplies: 1Last Post: 20th Oct 2018, 23:40 -
No format plays as smoothly as raw MiniDV AVI files
By jackdarabbit in forum Newbie / General discussionsReplies: 15Last Post: 19th Feb 2018, 18:04
