Hi guys I´m encoding some mkv videos that I have they are in 1080 and 2160, I´m confused because the quality, I mean the colors it´s not the same, I mean I encode from 2160p to 1080p and compared with the same movie but the mkv remux the colors of both are differents, take a look the screenshoot
This is from Bluray 1080p remux
[Attachment 67062 - Click to enlarge]
This is from 2160p encoded in 1080p
[Attachment 67063 - Click to enlarge]
As You can see there are different and I so confused and I so need to know if the second image colors are ok and I can go ahead or whats happens?
Thank You in advance
Results 1 to 21 of 21
input is HDR, output is SDR, but you missed doing an HDR to SDR conversion. Usually one would do an HDR->SDR conversion using some tone mapping method.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
I would keep the HDR version.
HDR changes the way the luminance and colors of videos and images are represented in the signal, and allows brighter and more detailed highlight representation, darker and more-detailed shadows, and a wider array of more intense colors. read: https://en.wikipedia.org/wiki/High-dynamic-range_television
If the PC's or laptop's display isn't capable of processing HDR10, you can try using various software players that do tone-mapping. If you have Windows 11, its Windows Media Player and Movies and TV App can tone-map HDR10. Recent versions of PotPlayer, VLC, and MPC-BE can also tone-map HDR10. (These are just the ones that I have tried. There may be more.)
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
any movie with HDR es better than SDR? no matters colors change?
Just because a movie is HDR or SDR doesn't say anything about its visual quality being better.
That is as wrong as saying that any movie with a higher bit rate must look better than the same movie with a lower bit rate.
Neither bit rate nor color space is a definitive quality indicator.
(Same goes for resolution, some DVDs of movies look better than their Blu-ray releases.)users currently on my ignore list: deadrats, Stears555, marcorocchini -
HDR is basically just a wider color and brightness standard for video (and pictures). SDR is standardized by Rec. 709 and HDR is standardized by Rec. 2020.
The difference comes through in a wider color gamut for HDR than for SDR. For brightness/luminance, the difference is in their "transfer function", which is difficult to explain and is basically just math.
Your TV or monitor's ability to display these different colors and brightness levels will depend on the manufacturer, even if it's listed as supporting HDR. You can think of it like a set of speakers - the speakers might be advertised as putting out 20Hz to 20KHz, but do they really? -
HDR defines a wider range of colors and brightness than any current TV can display. It then becomes the TV's job to reduce the range to something that it can display, in a way that's best for that TV. So different TVs will look different when displaying HDR video, even when "perfectly" calibrated.
Try to find the so called pipet function, where you "pick" the white and black points in the footage otherwise you need pro software..
Davinci Resolve …. -
DV Quality or Super Video Quality??
By Caius in forum Capturing and VCRReplies: 73Last Post: 18th Apr 2022, 09:37 -
What Is The Best Video Codec For Small File Size With Best Video Quality??
By DJboutit in forum Video ConversionReplies: 2Last Post: 14th Feb 2021, 07:58 -
Poor Video Quality in Digitized Sony Video8 Tapes (Video Attached)
By wsd33904 in forum Capturing and VCRReplies: 7Last Post: 16th Jan 2021, 18:47 -
analog video capture - artefacts, poor video quality, lost connections
By kaeffchen_heinz in forum Capturing and VCRReplies: 8Last Post: 5th Nov 2020, 08:39 -
Incorrect video cut timing on MKV video with lossless quality
By may5224 in forum EditingReplies: 8Last Post: 19th Nov 2019, 15:02
