The video is 30 fps progressive and the frame pattern is AAABCD. Basically there are 2 duplicates on every pattern.
Removing 2 of every 6 frames from a 30p video will leave you with 20 fps. That's not a common frame rate. There may be missing frames too. It might be possible to restore those missing frames. If you post a sample (include a medium speed panning shot) we can analyze it for you.
Avisynth script for "Decimate/Restore->23.976" only
By theholmboy in forum Video ConversionReplies: 2Last Post: 3rd Aug 2021, 14:12 -
Avisynth+ and grabbing x frames every y frames? I'd like to sample a clip
By Msuix in forum EditingReplies: 2Last Post: 11th May 2021, 15:41 -
How to properly decimate frames to make the video shorter on Virtual Dub 2?
By pernicio in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2019, 05:31 -
Replace random duplicate frames with black frames (AVISYNTH)
By benzio in forum EditingReplies: 7Last Post: 31st Jan 2018, 16:43 -
Deleting bad frames using Avisynth
By pooksahib in forum Video ConversionReplies: 11Last Post: 8th Oct 2017, 09:26
